I bought a used LitePlacer and converted it to my needs.
It now runs OpenPNP, has HeapFeeder, StripFeeder, BlindsFeeder and LoosePartFeeder. Good for me as an hobbyist or prototypes, for larger production runs, that setup would be no fun. (Can find some information on my homepage, most in german and only reachable using IPv6:
https://www.formann.de/)
But adding "real" feeders would change that.
To sum it up I'd say, it depends on your expectations and requirements. The mechanical basis should be ok up 0402/0.5mm pitch, but it is not a "turnkey-solution" and I would suggest taking a look at OpenPNP as the software. (And if you do not get a used LitePlacer cheap, building your own, there are better heads available)
Regarding the oven: I build myself one based on the
https://www.whizoo.com/controleo3, with heaters on both sides.
But nowadays I'd think about a "fryer type" galden machine, mixing very large and small parts with a infrared oven is not always so simple...
