A center-fiducial is used for precision placement of a part if the camera can not see all the pads of the footprint. in order to find the exact center of placement the camera needs to be able to see the 4 corner pads so it can run two diagonal seeking algorithms and determine the center location. if a part is really big ( like those lecroy parts ) the field fo view of the camera is not large enough to capture this in one shot. so that's when a dead-center fiducial comes into play.
But what if the chip center placement is already programmed in as part of the pick'n'place file?
Dave.
Ah, looks like somebody needs a bit of an explanation
The machine indeed goes by the coordinates given in the pick and place files. Most commonly it goes by the center coordinates. What if the board has an offset compared to the 0:0 point of the machine ? Then all programmed center coordinates will be 'off' by that offset. So that is why the pick and place head has another, downward looking camera. Instead of traveling to the pick and place coordinates given with the part , it travels there with the camera. The camera has a fixed offset from the nozzle as it 'rides' on the nozzle carriage. The camera now finds the center fiducial and compares the coordinates given by the positioning electronics of the stage ( essentially the feedback of the encoders on the stage ) +/- the coordinates inside the camera viewport to the numbers given in the file. Any residual offset is now compensated.
Boards, especially large boards do tend to 'shift' in pick and place machines under the vibration.
As for components 'settling' during reflow : that is only true if the mass of the object is less than the upward force given by the combined surface tensions of the liquid solder and only during the short point in time the solder is liquid but has not yet 'wetted' the part.
The moment 'wetting' kicks in then we deal with sideways forces , again dominated by the surface tension , but this time the pin is not 'on top' of the solder bubble, but inside the bubble. Think of it this way. The liquid solder is a little droplet of water. When the pin has not wetted yet it needs to pierce the surface of this droplet and try to get inside the droplet. Each pin has its own droplet so it is the combined force. Once wetting occurs the pins are inside the droplets. So now the surface tension keeps them nicely centered inside the droplet. Try to pull them out ( you are trying to escape from the inside, so you try to pierce the surface tension from the inside out) and the surface tension will push you back to the center.
Have a very heavy part, like a ceramic hybrid and you don't stand a chance moving it ... The combined surface tension does not have enough force to do it.
Have a very light part and you get the opposite effect : drawbridge where one pad did not flow and the part sits slanted. Or plain tombstoning where there is too much solder and the forces actually succeed i pulling the part vertically with one leg In the air.
Keep in mind that fabrication machinery has improved as well and at the time that lecroy board was made machines were less precise. Today I doubt the machines would require the fiducials.
I was at mvinix ( a subcontractor I use to assemble boards) a couple of months ago and they just installed a brand new Panasonic placement machine that handles 01005 packages ... 0805, 0603, 0402, 0201, 01005 <-this is where we are ... That stuff is literally 'dust'. If you throw a couple of these in a ziploc bag you can't find them with the naked eye ( at least I can't ).
That machine is fully self aligning and uses a very clever technique. It has one stud on the side that has a tiny crosshairs laser engraved on it. The machine first goes there with the downward camera and 'homes' itself to that point. Then it goes with the nozzle over the upward looking camera and finds the exact offset of the centre off the nozzle. It then goes and picks up the smallest part it has on its feeders , moves this to the upward camera, spins it around and centers this part I. The field of view of the upward camera. It now goes to the crosshairs and place the part there. Using the downward looking camera it now figures out the placement error of the part on the crosshairs ( the crosshairs is like a graticule with division marks so the machine can read both exact center ( which it set as 0:0 ) and the subdivisions. The machine now knows the offset between upward looking and downward looking camera as well as the nozzle position
So it can now compensate for any mechanical intolerance in the entire stage. Simply brilliant.
If maintenance was done and the cameras were removed for lens cleaning you have slight errors. No problem. During machine reset the machine fully nulls itself using a sacrificial part.
Now, this machine actually has two downward looking cameras that sit under a 45 degree angle in respect to the board. So it can actually look underneath the part... For the 01005 and 0201 parts it simply uses the pads of the component footprint as fiducials! As the nozzle with part is over the placement position the camera seek both pads on the board, apply all offsets ( stage, camera, nozzle , part ) and then thinks the part down. Before departing the placement site it uses the cameras again to verify correct placement. If ,for some reason ( vibration , part cracked , not enough solder paste on one pad ) the part has shifted , the machine will actually attempt to pick it up and reposition it. If it fails after two attempts it puts in an 'operator' notice that part xyz has a placement error and needs to be corrected by hand.
Incredibly clever bugger that machine. Costs 1.5 million$...
