Author Topic: Need help on SMT802 or TVM802  (Read 401 times)
Offline tgcoderTopic starter
« on: May 21, 2023, 11:54:15 pm »
I just purchased this SMT802 machine a couple weeks ago. It looks very similar to the TVM802.  I've spent part of my time trying to understand it so I can run one of my boards thru it.  I've come to a halt trying to configure the IC Stack whereby I have several components in a tray. The documentation only shows an example for only one components for each tray.  For example, I have 3 components in tray 1. One component at the upper left, another in the center and the last one at the lower right. I would call that Stack1.  What would I use for the start and end coordinates?  The array would be 1,1 being that only one tray is used.  Can anyone show me an example of what the parameters would be?
Offline Ihron1000
  • Country: ru
Re: Need help on SMT802 or TVM802
« Reply #1 on: May 22, 2023, 08:02:18 am »
You need to point the nozzle at the first component, click remember and do the same on the last component, then specify the number of columns and rows.If the vibrating feeder, the beginning and end are the same , and the column and row are selected 1 and 1.
