Author Topic: Neoden 4 pick and place  (Read 358039 times)
Offline mairo
Re: Neoden 4 pick and place
« Reply #1475 on: December 08, 2019, 12:41:47 pm »
Does any one know if the two Neoden eBay accounts - 'neoden' and 'neodentech' are both legit> I think I have seen the 'neoden' account from before, but now there seems to be also a 'neodentech'...
Thanks
Offline pete_flex
« Reply #1476 on: December 13, 2019, 11:41:29 am »
Does anyone have NeoDen's stated part placement accuracy? is it around 80 microns?
I have the X/Y positioning as 5 microns just don't see a placement figure. thanks
Offline GerardG
  • Pick and Place support manager
    • electronicatools.com
« Reply #1477 on: December 16, 2019, 08:36:47 am »
Hello Pete_flex,
Positioning resolution is not exactly what you need.
XY-repeatability +/-0,02mm
We place 0402 with the machine during demonstration. And show the result under the microscope.
0201 is also possible when fine tuning the placement and pickup height.
Regards,
Gerard
Offline cschew
  • Country: my
« Reply #1478 on: January 17, 2020, 07:21:37 am »
Need advice to solve the below problem:
Neoden 4 shown Attention message: Photography failed! try again.
Thank you
CS Chew
Offline luiHS
    • Pinballsp
« Reply #1479 on: February 05, 2020, 12:21:32 am »
Thank you
CS Chew
I am having the same problem, and that is a failure of the camera or the cable that connects to the camera. I am waiting for a camera replacement to be sent to me from China on the 9th.
The complicated thing is to access the camera to replace it, you have to remove all the feeders on that side, and move the rail that hides 3 screws.
« Last Edit: February 05, 2020, 09:21:12 pm by luiHS »
Offline GerardG
« Reply #1480 on: February 05, 2020, 08:13:51 am »
Hello LuiHS,
We have spare parts stock for N4 ,IN6 and S1 in the Netherlands.
If under warranty we could have sent it to you.
Offline luiHS
    • Pinballsp
« Reply #1481 on: February 05, 2020, 11:24:03 am »
Hello LuiHS,
Hello.
Yes, my Neoden4 is under warranty.
How can I get the camera and the cable?
Can you provide complete instructions or a video where I see exactly how to replace the camera? The document I have does not show it in detail, it only reaches the step of removing the 3 screws from the photo.
regards
Offline tboicey
« Reply #1482 on: February 05, 2020, 06:20:52 pm »
Posting this here, hope it is allowed.
There is a Neoden 4 for sale here in Ottawa, Canada. I know the seller and have seen the machine. Basically new.
No financial interest, etc. etc. Just pointing this out in case somebody wants a machine that is already in North America.
https://www.kijiji.ca/v-other-business-industrial/ottawa/new-neoden4-pick-and-place-machine-smt-for-sale/1478950574
(Price is in Canadian Dollars)
Offline jdrexler
  • Country: cz
« Reply #1483 on: May 08, 2020, 11:23:35 am »
Hi guys,
do you have please someone experience, how to solve following vision problem?
We have problem with vision recognition of following chip (image attached). We also tried increase light, but still Neoden doesn't see this type of smd parts..
Others are working fine.. Do you know, how can we fix it?
Thank you
Online MR
  • Country: tw
« Reply #1484 on: May 09, 2020, 11:18:36 pm »
I don't have a neoden but...
How about cleaning the dirty nozzle and adjusting the camera settings (contrast, brightness) contrast up / brightness down.
You need to remove all the dust from the picture for the optical recognition...
« Last Edit: May 09, 2020, 11:21:12 pm by MR »
The following users thanked this post: jdrexler
Offline nisma
« Reply #1485 on: May 10, 2020, 11:43:31 am »
I suppose the Problem is the inner circle from nozzle. The intensity is similar as the component. Four additional TH LEDs at the correct angle should resolve the problem. For that component just one single led is probably enough but four for not influencing negatively other component recognitions.
Offline jdrexler
  • Country: cz
« Reply #1486 on: May 10, 2020, 05:55:33 pm »
Hello,
thank you for help. Additional side LED light solve it and vision recognized it correctly. We will try develop some extra light for this type of components.
Thank you,
Jan
Offline itdontgo
    • IoT Manufacturer
« Reply #1487 on: May 17, 2020, 12:02:29 pm »
We had this. The positioning of the cable meant that it would hit something every time it started up. Eventually, it cut through some of the conductors inside it.
I asked them for a replacement then realised what a massive pain it would be to swap it as it's connected to an internal USB. They said you could just plug it in to an external USB on the machine but instead I just soldered the broken wires back together and relocated the cable. It's never been any trouble since.
There was another annoying problem where the end stop photo sensor was misaligned and the x-axis used to crash into the end.
These two problem spoilt was is otherwise a really good and reliable little machine. Since I fixed them it's been great.
