Hi.
Tired of the painful process to setup the Neoden TM245P Pick and Place, I decided to make a mod to OpenPNP to export a CSV file compatible with the Neoden machine.
This way I can reuse component database and check if required components are present or need to be installed on free feeders.
But that isn't enough. I really want to install a vision system and make it compatible with OpenPNP to control the machine.
Today I opened the bottom plate and collected some information to check if the upgrade is possible using the original electronics.
Here I share my findings...
The guts of the TM245P consists of:
- a motherboard (model TY164) with TFT LCD and resistive touch
- a power supply and control board (model TY131)
- two microstep driver
- two vacuum pumps
- one air blower
- a transformer
The motherboard have a STM32F407ZGT6 and a RA8875L3N TFT LCD Controller. The SD card slot can be seen on the left side of the board.
At the center there is a 26 pin IDC connector that goes to the power supply and control board.
On the top a 3 pin SWD connector and on the right side a 2 pin connector that powers the vibration feeder can be seen.
The board uses as power supply 24V that comes from the power supply and control board. There is a 5V step down regulator (LM2576S-5.0) that supplies the uC through a 3.3V Linear reg.
The 5V rail are sent back to the power supply and control board.
This is the microstep driver:
The power supply and control board have 4 diode bridge rectifiers (GBU808 on bottom layer) with +100V, +30V, +12V and -12V labels.
There are four step down regulators (LM2576T-ADJ): +30V->+24V, +30V->+24V, +12V->+9V e -12V->-9V
And the following connectors:
- P1 -> Transformer (label 220V)
- P2 -> air blower (connected to AC input)
- P3 -> Transformer (label 110V)
- P4 -> AC input and on/off switch
- P5 -> Transformer taps labeled 70V, 23V, 11V, 11V
- P6 -> To motherboard
- P7 -> Power Supply to step controller X axis (connected to 100V labeled line)
- P8 -> Power Supply to step controller Y axis (connected to 100V labeled line)
- P9 -> X axis step controller signals (EN, DIR, STEP)
- P10 -> Y axis step controller signals (EN, DIR, STEP)
- P11 -> To DB9 connector at the back of the equipment (CAN-H CAN-L JTMS e JTCK
- P12 -> Endstop Y axis switch
- P13 -> Pick and place head
- P14 -> Vacuum Pump A
- P15 -> Vacuum Pump B
- P16 -> Endstop / origin Y axis switch
- P17 -> Feeder block 1
- P18 -> Feeder block 2
The feeders and the head are controlled through a CAN bus connection. The same bus goes to the back DB9 connector.
This is the 26 pin connector pinout from the motherboard:
I tried to read the firmware but the uC have Level 1 Read Protection.
The next step is to log the CAN communication while sending simple commands using the equipment GUI.
Then I will check if the X and Y axis can be controlled through CAN messages.
Does anybody have the CAN message specification?
Anybody tried to mod this machine?
Best Regards,
Luiz Renault
