Author Topic: Now you could choose color pcb on PCBWay  (Read 2638 times)
Offline ansonbaoTopic starter
  • Country: cn
  • Never stop learning
    • pcbway
« on: May 02, 2024, 09:47:03 am »
Hello everyone
Now you can select color PCB on PCBWay. You just need to select "UV Printing Multi-Color" in the silk screen and provide the rendered picture.
There are a few points to note:
1.Drill holes, traces, soldermasks, and outline designs must comply with specifications.
2.When designing colored characters, avoid areas with solder mask openings, such as avoid placing them over surface-mount pads and through-hole pads.
3.Colored characters can be provided through reference pictures and reference alignment map (for easy alignment with PCB), without the need to be designed in Gerber files. If designed in Gerber files, they should only be placed on the silkscreen layer and annotated with colors.
4.Overall effect files of colored boards support the following file formats: AI, PDF, JPEG, PNG, TIFF, etc.The clearer the picture, the better the effect.
More details check here. If you have any questions or suggestions, please leave a comment.
And in order to thank our customers at eevblog for your support, I will provide you with discounts if you need color PCB, please send me a private message
I am PCBWay manager and you can ask me any questions about PCB.
The following users thanked this post: thm_w, igendel
Offline Vertamps
Image location
« Reply #1 on: May 07, 2024, 06:03:11 pm »
Can you specify the Image location/ resized-bounding outline in a mechanical layer Gerber file and do you stretch to fit the boundry?
Does the pcb house automatically remove conflicting (over exposed copper) image printing from the solder mask layers?
-Vertamps
Online tooki
Re: Now you could choose color pcb on PCBWay
« Reply #2 on: May 07, 2024, 08:12:53 pm »
Sounds like a great service, but you really need a fully-fluent, human, electronics-savvy Chinese-to-English translator to write the English text, because it’s really unclear right now. The requirements are not really understandable. :(
Offline thm_w
  • Non-expert
« Reply #3 on: May 07, 2024, 10:07:01 pm »
Its fairly clear to me: Give them the picture and a reference image showing where the image is placed on the PCB and how it is scaled.
You could probably add four corner points on your silkscreen to help them to align it, assuming a square photo.
  • Country: cn
    • pcbway
Re: Image location
« Reply #4 on: May 14, 2024, 06:58:13 am »
-Vertamps
For the first question,I don't understand what you mean clearly,could you explain that?
Usually the process is like this:
1. If you give us pictures and board renderings, we can adjust it;
2. If a certain layer of gerber data is given, then we can do it based on a certain layer of gerber data, but we can only print one color.
So I suggest using the first method, it will be more convenient.
For the second question,Yes,we will remove it
« Last Edit: May 14, 2024, 07:00:53 am by ansonbao »
The following users thanked this post: Vertamps
  • Country: cn
    • pcbway
« Reply #5 on: May 14, 2024, 06:59:32 am »
Thanks very much for your feedback. I have asked my colleague to review the text again. If you need color printing, please let me know and I will give you a discount.
  • Country: cn
    • pcbway
« Reply #6 on: May 14, 2024, 07:00:23 am »
yes,you totally get it
