I found this rather a different solution to the feeder problem.Just a box full of components and by rotation and mechanically "filtering" and manouvring end like a stickfeeder. Would be nice to have a very small version for 0402 and 0603 of this https://youtu.be/V85rAGrqfzY
and only about $21,000 per feeder for those bulk feeders. Mind you can you stack nearly 400,000 parts in them. AT placement rates of 50,000 parts/hour its only a shift full.
Very common in LED strip companys. The cost of putting LEDS in tapes can exceed the cost of the compoents sometimes. Getting them raw is just about saving money.
Quote from: mrpackethead on September 28, 2018, 08:39:31 amand only about $21,000 per feeder for those bulk feeders. Mind you can you stack nearly 400,000 parts in them. AT placement rates of 50,000 parts/hour its only a shift full.Nobody asked for prices, OP said he would like to see that for smaller components
Quote from: cgroen on September 28, 2018, 08:58:07 amQuote from: mrpackethead on September 28, 2018, 08:39:31 amand only about $21,000 per feeder for those bulk feeders. Mind you can you stack nearly 400,000 parts in them. AT placement rates of 50,000 parts/hour its only a shift full.Nobody asked for prices, OP said he would like to see that for smaller components Vibratory feeders are mostly for smaller components. Does anyone use any other kind of feeder for 0201 and smaller?
Quote from: coppice on September 28, 2018, 09:53:50 amQuote from: cgroen on September 28, 2018, 08:58:07 amQuote from: mrpackethead on September 28, 2018, 08:39:31 amand only about $21,000 per feeder for those bulk feeders. Mind you can you stack nearly 400,000 parts in them. AT placement rates of 50,000 parts/hour its only a shift full.Nobody asked for prices, OP said he would like to see that for smaller components Vibratory feeders are mostly for smaller components. Does anyone use any other kind of feeder for 0201 and smaller?Plenty of parts avialable on tape for 0201. Not sure what you do smaller than that. I dont' even want to think about it.
Yes, they are available, but only the better machines can handle them. However, the better machines also offer vibratory feeders, most of them far more compact than the one which started this thread. This makes we wonder if many people really use the taped parts, when the solid block packaged parts are considerably cheaper.
