Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Manufacturing & Assembly
PCB eyelet??
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: PCB eyelet?? (Read 3998 times)
glicos
Regular Contributor
PCB eyelet??
on:
December 18, 2016, 05:12:15 am »
Anyone can tell me what is this called? It some sort of PCB socket terminal soldered directly to the board. Is this a PCB eyelet or there's a proper term for this and where can i order? Many thanks for those who will answer..
Logged
ataradov
Super Contributor
Country:
Re: PCB eyelet??
Reply #1 on:
December 18, 2016, 05:26:25 am »
I'm not sure if this is the same thing, but I've seen this type of connector
http://www.te.com/usa-en/product-2-331677-2.html
used for connecting battery compartments to PCBs without soldering. Sounds like the same idea, but I don't know if they will work for ICs.
Logged
Alex
ataradov
Super Contributor
Country:
Re: PCB eyelet??
Reply #2 on:
December 18, 2016, 05:28:27 am »
Basically search for "PCB spring socket" and you will find many options.
Logged
Alex
Richard Crowley
Super Contributor
Country:
KJ7YLK
Re: PCB eyelet??
Reply #3 on:
December 18, 2016, 07:37:14 am »
Those are NOT just "eyelets". Those are machine-screw female IC pin sockets. They come in a pre-spaced strip for easy insertion into the PC board holes. Then after soldering, the carrier tape is stripped away.
http://www.allelectronics.com/item/psip-80/peel-a-way-r-machine-pin-socket-strip/1.html
Logged
salbayeng
Frequent Contributor
Country:
Re: PCB eyelet??
Reply #4 on:
December 18, 2016, 07:57:09 am »
Mill-Max are the most prolific manufacturer of these ,
Click on the data sheet link on the first hit here:
http://au.mouser.com/Mill-Max/Electromechanical/Hardware/Circuit-Board-Hardware-PCB/_/N-5g2e?P=1z0zl2rZ1ywa5efZ1yx7haj
I've always called these "machined pin sockets" , but it seems "pin receptacle" is a more common name.
Most IC pins are equivalent to 20mil = 0.020" = 0.5mm diameter.
Logged
jpanhalt
Super Contributor
Country:
Re: PCB eyelet??
Reply #5 on:
December 18, 2016, 09:57:27 am »
Here is a listing.
http://www.digikey.com/products/en?FV=fff40016,fff8049c&k=MillMax
You can buy them with a "conventional" plastic holder or just a metal carrier. I like the low profile they provide. The plastic sockets can be purchased with built-in decoupling capacitors for logic chips.
To duplicate the assembly you show, you need to get the version with a metal carrier. The carrier is like a disposable IC with the pins on each leg. It keeps the bare pins aligned during soldering. Then remove the carrier and install the IC.
John
Logged
richardlawson1489
Regular Contributor
Country:
Re: PCB eyelet??
Reply #6 on:
December 30, 2016, 07:01:49 am »
I think it is PCB pin socket. May you can find it from pcbshoppers, pcbway or even ebay.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB eyelet??
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
