Author Topic: PCB eyelet??  (Read 3955 times)
Offline glicosTopic starter
PCB eyelet??
« on: December 18, 2016, 05:12:15 am »
Anyone can tell me what is this called? It some sort of PCB socket terminal soldered directly to the board. Is this a PCB eyelet or there's a proper term for this and where can i order? Many thanks for those who will answer.. :-//
Online ataradov
    • Personal site
Re: PCB eyelet??
« Reply #1 on: December 18, 2016, 05:26:25 am »
I'm not sure if this is the same thing, but I've seen this type of connector http://www.te.com/usa-en/product-2-331677-2.html used for connecting battery compartments to PCBs without soldering. Sounds like the same idea, but I don't know if they will work for ICs.
Alex
Online ataradov
    • Personal site
Re: PCB eyelet??
« Reply #2 on: December 18, 2016, 05:28:27 am »
Basically search for "PCB spring socket" and you will find many options.
Alex
Offline Richard Crowley
  • KJ7YLK
Re: PCB eyelet??
« Reply #3 on: December 18, 2016, 07:37:14 am »
Those are NOT just "eyelets".  Those are machine-screw female IC pin sockets.  They come in a pre-spaced strip for easy insertion into the PC board holes. Then after soldering, the carrier tape is stripped away.
http://www.allelectronics.com/item/psip-80/peel-a-way-r-machine-pin-socket-strip/1.html
Offline salbayeng
Re: PCB eyelet??
« Reply #4 on: December 18, 2016, 07:57:09 am »
Mill-Max are the most prolific manufacturer of these ,
Click on the data sheet link on the first hit here:
http://au.mouser.com/Mill-Max/Electromechanical/Hardware/Circuit-Board-Hardware-PCB/_/N-5g2e?P=1z0zl2rZ1ywa5efZ1yx7haj
I've always called these "machined pin sockets" , but it seems "pin receptacle" is a more common name.
Most IC pins are equivalent to 20mil = 0.020" = 0.5mm diameter.
Offline jpanhalt
Re: PCB eyelet??
« Reply #5 on: December 18, 2016, 09:57:27 am »
Here is a listing.
http://www.digikey.com/products/en?FV=fff40016,fff8049c&k=MillMax
You can buy them with a "conventional" plastic holder or just a metal carrier.   I like the low profile they provide.   The plastic sockets can be purchased with built-in decoupling capacitors for logic chips.
To duplicate the assembly you show, you need to get the version with a metal carrier.  The carrier is like a disposable IC with the pins on each leg.    It keeps the bare pins aligned during soldering.   Then remove the carrier and install the IC.
John
Offline richardlawson1489
    • PCB Assembly
Re: PCB eyelet??
« Reply #6 on: December 30, 2016, 07:01:49 am »
I think it is PCB pin socket. May you can find it from pcbshoppers, pcbway or even ebay.
