We are a PCBA manufacturer based in Shenzhen. To ensure smooth assembly, we always conduct DFM checks prior to PCB production and component procurement.
Currently our engineers can only run automatic verification on SMD pads with the existing DFM tool. Through-hole dimensions have to be measured manually.
Could you recommend cost-effective DFM software that supports full automatic inspection for all components?
Thanks in advance!:)
