@thommo: Thanks!
@Bob, rwb:
We won't do any fine pitch or BGA stuff, at least for now. I see this as an entry level machine to produce the first generation of our controller boards. They have around 30 parts, mostly 0805, some TSSOPs and SOT23. The boards will be panelized with a typical run being 20 panels with 6-8 PCBs each. We wanted to have the boards made but the online calculators we tried were like $10 per board for manufacturing alone. With a little luck the machine will pay for itself after a few runs.
The machine comes with a sample PCB (33 x 100mm) that has some fine pitch components on it (.5 or .65, not sure). Once I get my hands on some cheap chips of the right size I will try this out. BGAs are most certainly not an option with this machine, the cameras are simply not good enough wrt resolution and optics. No leads, maybe.
Regards, Axel
