I am planning to order a pick and place machine from China.
There is a solid need to make some boards monthly, placing around 150 000 components monthly.
I see the lower cost machines have 4 nozzle heads, so i started to think, is it possible to use them efficiently when our board has a lot of 0603 passives, but also some QFN32, QFN16, Dpak-transistors, smd POT, bigger diodes, switch and USB connector.
I was thinking, it would slow down the machine if there was many different nozzles needed all time, and for example just one of the nozzles could place the 0603 parts which are the most numerous components on board. Is the changing of nozzle during the operation some easy and well integrated option, or how it works? Or should boards be run for example first with all nozzles for 0603 to make many panels ready with these parts as quickly as possible, and then change nozzles and program, and place the other components?
