Author Topic: Pick & Place MachineTVM920  (Read 163542 times)
Offline dtf
Re: Pick & Place MachineTVM920
« Reply #50 on: September 18, 2016, 03:52:43 pm »
Is there a part number or rating printed on the current vacuum pump, which i assume is a venturi type?
Is there also a vacuum reservoir, pressure gauge, check valve etc? ie. could the venturi simply be swapped out with a larger one?
Does a pick and place really need a large volume of vacuum? And in this vacuum flow test what was the pressure and CFM rating of the compressor you used to power the venturi?
Online ar__systems
« Reply #51 on: September 18, 2016, 05:14:49 pm »
It is not venturi type.
The following users thanked this post: daveshah
Offline dtf
« Reply #52 on: September 18, 2016, 08:11:00 pm »
ah, that's weird, why does QiHE specify such a large air supply is needed?
Is it a small electric aquarium style pump?
Offline thommo
« Reply #53 on: September 19, 2016, 12:52:58 am »
Hi DTF,
I think this forum is at mixed causes once again.
The discussion you are referring to is with regard the TVM802 model - which I understand does not require an external supply. I assume you are in fact referring to the TVM920 model [which does].
Peter
Offline dtf
« Reply #54 on: September 19, 2016, 01:27:52 am »
I am talking about TVM920 (as the thread title) which requires an external compressed air supply of 95L/min @100psi according to QiHE, which is used for the feeders of course, and what i assumed is a venturi vac pump
so all the vacuum pump talk was about the older machine and not TVM920?
Offline thommo
« Reply #55 on: September 19, 2016, 09:14:37 am »
Yes - I believe so.
This forum knows of only one 920 machine 'in the wild' so far, and our is on its way this coming Monday.
Harry owns a TVM802 machine.
Hope this clears things up.
Peter
Offline dtf
« Reply #56 on: September 19, 2016, 04:38:52 pm »
Good stuff. Mine is on the way too :)
Offline harry4516Topic starter
    • www.dj0abr.de
« Reply #57 on: September 19, 2016, 06:50:04 pm »
two 920's on its way to Canada, great !
Lets see if the 920 uses a venturi type pump or the tvm820's aquarium style pump.
I am very curious to know how strongly the parts adhere on the nozzles.
The other thing I like to know is how easy or hard it is to mount a board in the TVM920.
With the 802 its very easy, this is one thing I missed with the 920 (from what I have seen in the few videos).
Offline IconicPCB
« Reply #58 on: September 19, 2016, 09:40:12 pm »
Harry,
Your video shows a machine with cut tape feeders and loose component bin feeders.
Are these feeders part of machine frame or are they removable?
If removable are they part of machine offering or did You purchase them separately?
If bought separately, where from and how much did they cost?
    • www.dj0abr.de
« Reply #59 on: September 19, 2016, 10:17:54 pm »
these feeders are homemade.
I have a mill and made these parts from aluminium. Mounted with 3 screws to the 802, so I can replace
it if other feeders are required.
The cut tape feeders are most important, there are so many parts I purchase in small quantities only.
The loose part bins are mainly for microcontrollers and other bigger parts.
Last week I did 25 boards with 58 different components, the left and back stack of the 802 was fully equipped and the other parts in the cut tape feeders.
Lets see how the 920 can handle these kind of things.
I was very close to purchase a 920. What makes me unsure is the housing, this would be the first thing to be removed, there are too many things to do in the machine and the housing is just in the way. The other thing is the PCB-holder, or the not existing pcb holder. This is very well done with the 802 and I miss it in the 920.
« Last Edit: September 19, 2016, 10:23:39 pm by harry4516 »
Offline IconicPCB
« Reply #60 on: September 20, 2016, 07:41:27 am »
Harry,
Very nice.
I too am looking for fixed feeders for my machine.
I made some cut tape feeders from a 6 mm thick phenolic board. The kind of material switch boards are mounted on.
I make milled printed circuit boards and unfortunately the milling machine can not handle aluminium ( it runs an Alfred Jaeger 100KRPM spindle).
The feeders worked out OK... but it turns out double sided tape on an aluminum plate is better at handling paper tape which has been rolled up.
Rolled up tape tends to buckle upwards unless the edges are held down along the entire length of the tape. Double sided adhesive tape therefore performs better in this regard.
    • www.dj0abr.de
« Reply #61 on: September 21, 2016, 07:50:08 pm »
and plastic tape is even worse. If the cover tape is remove just touch it gently and all parts will jump in all directions.
Offline dtf
« Reply #62 on: September 27, 2016, 07:07:12 pm »
QiHE has sent me pix as they assemble and test my machine, they said it should ship this week.
The following users thanked this post: sparkswillfly, cgroen, zszabo
Offline dtf
« Reply #63 on: September 30, 2016, 12:03:42 am »
QiHE said it will ship today... these images are boring so I will just link them.
http://i.imgur.com/2EFrjgt.jpg?1
http://i.imgur.com/YrVNW7v.jpg?1
http://i.imgur.com/2gq6y6B.jpg?1
I also got their 'high precision' stencil printer and T960 oven to try out.
edit: they want $336 more in shipping :( and shipping will be later next week due to another long holiday.
« Last Edit: September 30, 2016, 02:16:10 am by dtf »
The following users thanked this post: zszabo
Offline zszabo
  • Country: hu
« Reply #64 on: October 05, 2016, 04:49:27 pm »
Hi Gus,
Anyone receive already a machine ?
Can share please first impression ? and second....
Thanks in advance.
Zoltan
Offline thommo
« Reply #65 on: October 05, 2016, 08:48:26 pm »
Ours arrives today guys [in about 2hrs actually if things go to plan] - I will let you all know once we've got it set up and evaluated things
The following users thanked this post: zszabo, dtf
Offline zszabo
  • Country: hu
« Reply #66 on: October 06, 2016, 08:40:53 pm »
Hi Peter,
Things goes out of planes ? I dont want to push You, just Im very courious. In next days I would have to arrange the payment for mine, and your experience could influence a lot.
If You have few "free" minutes could You share some impresion/images about Your machine ?
Thanks so much !
Zoltan
Offline thommo
« Reply #67 on: October 07, 2016, 01:30:55 am »
Hi Zoltan,
I wrote a rather detailed response, then captured some images, and proceeded to delete what I had written. Dumb!
TVM920 - initial impressions
I am very impressed by the build quality.
So far, all that we have had time to do is unpack the shipment and check the contents.
It certainly looks like a very well build and finished machine and at this point, I would have no hesitation in recommending this to anyone considering it.
This is a substantial machine and it appears that QiHe have learned a lot in their years of manufacturing the smaller versions of the PnP machines. It certainly appears 'fit for purpose'.
I will provide more information as we progress to set-up.
For now, it remains my opinion that it is the best machine I am aware of in this sector of the marketplace.
I can recommend that you contact a salesperson called Daisy who was incredibly helpful and knowledgeable during our pre-sales process.
Please mention my name - 'Peter from Melbourne Australia' and that I recommended QiHe and to speak with her.
Skype address for Daisy is:    daisyqiu1994
« Last Edit: October 07, 2016, 01:53:54 am by thommo »
The following users thanked this post: cgroen, protoneer, zszabo, dtf
Offline thommo
« Reply #68 on: October 07, 2016, 01:50:12 am »
REFLOW OVEN - Torch R350
Though not strictly part of this 920 forum page, I thought I'd include some basic information about the Reflow Oven we purchased to compliment the TVM920.
It is from a company called Torch based in Beijing. The heating design is a combination of dark IR [pre-soak] and dispersed Convection [reflow] and, from memory, it has about 12 controllable zones. My comments regarding initial reaction, build, and unpacking apply equally to this oven as they did to the TVM920 [which I'm very happy to be able to say].
The contact at Torch has been a person called Sara, and I dealt with her throughout the pre-sales process.
Her English is perhaps not as 'deep' as Daisy's [from QiHe] but we managed to get the order completed.
This item too is no toy, and is very solid in construction, and certainly appears 'fit for purpose'.
Skype address for Sara is: sara_h632
Again, please mention my name - 'Peter from Melbourne Australia' when and if you contact her.
The following users thanked this post: cgroen, zszabo, SVFeingold
Offline dtf
« Reply #69 on: October 07, 2016, 03:30:51 am »
Looking good thommo  :D
Any pics with human for scale?
Offline thommo
« Reply #70 on: October 07, 2016, 03:58:16 am »
Well - not so far DTF
No selfies allowed in this forum apparently    :-)
TVM920 is 1,100 wide, 900 deep and 750 high
R350 [reflow oven] is 1,500 long and 750 deep
Offline dtf
« Reply #71 on: October 07, 2016, 04:46:03 am »
Going to be a bit bigger, too, with feeders hanging off of it :)
Offline zszabo
  • Country: hu
« Reply #72 on: October 07, 2016, 06:10:14 am »
Thank You so much Peter ! Looks good, You are so prepared as You may became a distributor :)
Please continue with updates on next steps, Im really courious how it works all together.
All the best !
Zoltan
Offline thommo
« Reply #73 on: October 07, 2016, 07:25:11 am »
Put simply guys, I was looking for a Manufacturer and Machine that would
1) fit my requirements
2) fit those which I anticipated of many others
3) generate a solid user-base around which practical and useful info would freely flow
4) provide a sufficiently large user-base so that 'adaptation' could potentially happen for things such as an 'independent SW Application' [or preferably adopt OpenPnP and it's 'vision' counterpart]. Having made this last point, I truly believe that QiHe will continue to listen to its users and respond in tempo - a hugely great benefit for any potential buyer.
So, though I have little, to no, interest in becoming a distributor, I would definitely like to promote this Manufacturer and Machine combination if it meets the expectations I currently have for it.
In this regard I think my direction and goals are similar to many others.
The ONE THING that made the difference and my decision easy [for me at least] is it's use of commercial-grade, reliable and easily swap-able component feeders. As you may already know, it uses the Yamaha CL type feeders which have been the backbone of many a PnP machine throughout the world for a long time now. They are pneumatic, so cheap to produce and maintain than electric feeders - the major downside being max feed rate is slower [but still plenty for most requirements.
So ... let's build the numbers guys!
This is a relatively expensive machine [from a hobbyist's point of view], and a very inexpensive machine from a CM's point of view, but I believe it is the sort of solution that is perfect for someone looking to accommodate up to 80+ diff components per load/project - [56x 8mm feeders + 30x tray-type], and needs to runs components no smaller than 0402. Intend to make custom 'trays' for each different project to handle the 1 & 2 off per board components, where the 56 feeders happen to 'run short'.
BTW - though I've not yet tried it, my design thinking here is to laminate some approx 3mm thick non-EDS material with double-sided adhesive, laser-cut the pockets in it to suit, then adhere it to a 6mm Aluminium plate. Quick, flexible and relatively easy solution to increase the max component-type count.
Cheers - Peter
Offline zszabo
  • Country: hu
« Reply #74 on: October 07, 2016, 07:32:51 am »
Thank You Peter, You are Great Guy ! Im so sorry that You are so far - dont think any scary about :)
Hope that we can build here the team of users and share experience and solution regarding our machines.
Have a nice day and good luck to the machine !
Zoltan
