Doing a dense PCB, and using loads of 0.6mm/0.3mm (0.3mm drill) vias as its all i can fit in.
I need to find the via resistance, and so therefore i need to know the playing thickness inside the via.
The board is 1.6mm thick and 4 layer and we request 20z copper (70um).
However, as you know, you ony get 2oz on the top and bottom, the inner layers end up being just one ounce, for a PCB
quoted as being "2oz".
Anyway, PCBWAY, in their web page, only quote plating thickness for 2oz copper. So presumbly that includes us?
PCBWAY say that plating thickness inside a via is only 18-25um from "standard process"....and is 30-50um with "medium difficulty",
and >50um with "High difficulty".
Anyway, what plating thickness do you think we could get in our 0.6mm/0.3mm vias?
I am pretty certain that the smaller the via diameter, the less is the plating thickness that can be acheived with it, though PCBWAY dont elaborate?
Though i appreciate , for more cost, one can elect to put ones manufactured PCB back into the plating bath to thicken up the
via barrels. But that more than doubles the cost of the board?
https://www.pcbway.com/capabilities.html
