What i did, was buy some good 2nd hand machines. I make about 300-1000 panels per month. I have 150 Slots for CL feeders, and a big tray. That has almost been neough to allow me to keep all my parts on the machines full time.
I'm able to switch between items with about 10 minutes effort. ( changing supports, rail widths, etc ). This is only possibel becuase i dont' have to strip down the machine. Its not optimal placement and moving components around would speed it up, but I get abetween 12,000-14,000 pph actual placement rates.
Would i suggest others to do this. Yes. but theres a proviso. Only if you either have some solid experience with the machines you are going to buy, Or you have someone who can help you out. Or be prepared for a long learning curve.
Also spend as much effort on Paste applicaiton and ovens as you do on teh PNP. They are not afterthoughts.
