From factory web, there are three footprints. Presumably, different footprint fitting different process?
Which one should I use? For single quantity prototype, hot plate, hand place under microscope. Tin/Lead 63% to 37%, (may be activated) resin flux, wash with isopropyl alcohol.
All pads have same central line agreeing with data sheet. 0.35mm between two small legs. 0.65mm between small and large legs.
a) plain small leg 0.30 x 0.20mm, large leg 0.30 x 0.56mm
b) L small leg 0.20 x 0.15mm, large leg 0.20 x 0.50mm
c) M small leg 0.40 x 0.25mm, large leg 0.40 x 0.60mm
(was swapped number small leg 0.40 x 0.25mm, large leg 0.60 x 0.40mm)
EDIT:
data sheet small leg 0.25 x 0.15mm, large leg 0.25 x 0.50mm
Plain is middle-of-road. M is bigger. L is smaller
The chip is lead-less (SON/QFN). Solder pads under chip. No wetable side wall.
many thanks
