A problem occured in the last run of the vapor phase oven. The container is sealed pretty good at the moment. There is only a small hole in the side wall for the heating element cables.
This poses a problem when it comes to pressure equalisation. The relatively cold PCB is lowered into the vapor phase. A lot of the gas condenses onto the cold surface in the first few seconds.
This would absolutely be correct. This raises another problem. If you lower the PCB into the Galden too fast, your re flow profile is going to be way too steep on the way up. With the 'static' frying pan method, i was effectivel 'preheating' the pcb. ( giving it a soak period ) by regulating the amount of energy that was going into the system. If you were to monitor the temp of the PCB, ( you'd need a thermocouple attached it ), you' would be able to control the rate at which it heated up quite well. Above the 'thick' galden cloud, is a 'soft' cloud, and that vapour provides a pretty useful way of getting teh board up to a temp 10 lower than the melt point of the solder paste.
Galden vapour is easy to disturb. you only need a tiny draft and you'll blow it out of the tank. However, If its 'still', it really does sit nicely, and unless you put LOTs of energy into it, its easy to keep it in the tank. Moving PCB's in and out of the vapor does create a lot of movement.
This causes the pressure in the system to drop, and air from the outside rushes into the chamber. This by itself isn´t a problem. But it gets problematic when lifting the hot PCB out of the vapor phase.
By lifting up the hot board into cooler parts of the chamber, the pressure rises. This causes galden vapor to get pushed out of the chamber. This of course means unwanted galden loss over time.
Currently I´m designing sorf of a reflux condenser. This will probably just be a 6mm copper pipe bent into an air cooled coil. The galden condenses in the pipe, and flows back into the container, while also providing a controlled pressure equalization.
That has proved to be an effective way of keeping galden in teh tank as well. I tryed using it to cool my frying pan project, and it worked. The big problem with teh frying pan project is that while i can get really good results, its a very long cycle time.. as the galden goes from cold to nearly cold, and thats the best part of 15 minutes.
Your design is really very clever using the cable lifts. Some of the commerical VP machines bring the board out of the vapour into the top of tank, and then a door closes between teh board and the bottom of the tank. I think thats doable with another cable lift. I'll try and draw a picture tommorrow of what i mean.
If that could work, you'd be able to get great cycle times, becuase you'd probably nto even need to cool the galden down.
