My plan was to create vacuum at the beginning. I actually think to use boiling point variation vs pressure to my advantage, lower pressure means lower boiling point.
I make some assumptions here, maybe I'm wrong, but the timing of events would be:
-put boards, close container
-create vacuum, not very hard, what allows a cheap 1 stage pump
-if I start to heat galden, boards won't actually increase temperature until vapors reach their surface. Lower boiling point means galden will evaporate sooner than 230C, (boiling point at 1 bar). This should help with temperature gradient. Avoids situation when vapors touch boards only when they are very hot and cause sudden increase in temperature. During this process, pressure inside container should gradually increase due to presence of vapors. By controlling carefully quantity of liquid galden versus container volume, should be easy to calculate needed galden qty to obtain 1 bar when vapors reach 230C, in this situation, inside pressure is equal with outside pressure, therefore we have same boiling point. Am I wrong?
-stop heater, cooling by whatever means necessary to control cooling slope, creating vacuum again inside
-when temperature is low enough, slowly allow air inside until pressure equalizes, then open container.
le: thinking of it, I may need to create a system to insert galden into container only after vacuum is created, otherwise I may extract galden vapors during vacuum creation process...
