Sorry for the bump, figured it's better here than a whole new topic..
I'm considering building an oven for our shop. It'll mainly be for prototypes, small batches, and for complex boards when I don't want to profile our big ovens (we have two heller convection ovens). End game, I'd like to have one that has a fast enough batch time to where it becomes feasible to use the vapor phase vs powering up the main oven for all but production runs.
Cost isn't going to be super important, as the alternative for us is to spend $20K for an Asscon oven.
I'm planning on modeling a lot of this off of vapor degreasing systems. They use incredible toxic solvents, as a result, limiting vapor loss is a safety concern.
https://www.baronblakeslee.net/vapor-degreasers/baronette/index.html is an example of a nice batch style vapor degreaser. They don't rely on a sealing lid, instead they go full force with the condensing coils to make sure vaport can't leave. Not having a sealing lid helps massively with pressurization, and cycle time.
Here's a quick mockup of what I'm think of thusfar: (Ignore the exact dimensions, this was before I found the mcmaster container!)
Basically, when doing multiple panels, the Galden will be constantly boiling, so the vapor cloud will always be present. The first set of condensing coils will constantly be condensing vapor. This effectively will stop most vapor from being above this point. Then there will be a 75mm gap, which is called "freeboard" in the vapor degreasing world. There will still be a bit of vapor here, but it will be cooling as it goes. Above this point, there will be another set of coils. This should condense the rest of the vapor that is still around.
This "layered" system allows for cycle times to be pretty fast, since you don't have to wait for the Galden to boil. It also allows there to be a nice temperature gradient to help with reflow profiling.
My current idea for the heater is to have a custom machined heater block with cartridge heaters inside it. (We use this for a reflow hotplate currently) This will be affixed to the bottom of the container, to heat from the bottom up. The coils will be liquid cooled using some sort of laser cooler or similar. The carriage system for the PCB I really haven't put much thought into yet, as that is a pretty easy part and will worry about it later.
https://www.mcmaster.com/3763K211/ is what I'm planning on using for the container.
Please let me know your thoughts! I literally just started brainstorming this yesterday, so I'm sure I'm overlooking a lot.
