Hi, I'm trying to find a good way to fix 2 PCBs together on top of each other.
Ideally I'm looking for a nut that I could solder on the bottom pcb. Then I could use a screw to fix the top pcb and the bottom one.
Or an insert that could work with the a 1.6mm pcb.
I wand my TOP and BOTTOM pcb to touch each other.
Thanks for any help.
