Author Topic: Can your PnP place this component?  (Read 1171 times)
Offline olkipukki
« on: November 08, 2018, 02:32:26 pm »
Not sure how it correctly called - is it some sort of a grip nozzle required?
Offline capt bullshot
Re: Can your PnP place this component?
« Reply #1 on: November 08, 2018, 02:48:33 pm »
Manufactures often sell this kind of connector with an additional thingy (e.g. an clipped on plastic part or a piece of attached kapton film) to ease PnP. This thing has to be replaced after reflow. The ones as shown look difficult for the usual vacuum based PnP heads.
The following users thanked this post: olkipukki
Offline SMTech
« Reply #2 on: November 08, 2018, 04:38:36 pm »
^^ what he said. This is why I advise not to use an SM connector without good reason. If you are working in volume or need to, fine, otherwise SM connectors can need tooling (bye bye labour saving) or available stock in a very specific part number that adds a pick pad to the connector, or placing with tweezers - maybe not as straight as you'd like.  Here is a datasheet for a similar terminal https://www.toby.co.uk/uploads/publications/263.pdf where you can see the last letter denotes a variant with pick pad and its an option, Samtec are quite nice, datasheets are readable and part number easy to derive... unlike Molex.
I can only assume some machines do use some form of gripper or the versions without pick pads would not exist, however plenty of machines don't have that option. Its not just male pin headers that have this problem, pin sockets can have the same issue as the holes dissipate too much of the vacuum,but some machines might not care or let you turn off the vacuum check for specific parts.
Offline mrpackethead
  • D Size Cell
« Reply #3 on: November 08, 2018, 06:37:31 pm »
That would be a challenge for me.
Offline hcglitte
« Reply #4 on: November 08, 2018, 10:55:02 pm »
What about U.FL / IPX connectors? My machine manages most of the time, but it's not ideal.
https://en.wikipedia.org/wiki/Hirose_U.FL#/media/File:2_mm_SMD_UFL_Socket.jpg
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #5 on: November 09, 2018, 12:08:41 am »
Dealt with a similar connector before, we were lucky enough to have a nozzle that just fitted between the pins. But as others have said usually connectors like these come with a little plastic cap or a piece of kapton tape that you pick them up with
Offline olkipukki
« Reply #6 on: November 09, 2018, 06:14:32 pm »
Ehhh, seems like they can process a custom-made order, not in a hassle free way as Samtec, but still they can...
"3. Contact JST for the top entry type headers with suction cap"
Alternative, gripper nozzles might cost a fortune  :o
https://www.europlacer.com/feature/smart-nozzles/
"Where vacuum is not appropriate, and devices require special handling, Europlacer offers a range of adjustable gripper nozzles. And we can design special nozzles around customers’ specific applications for any odd form components."
or
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #7 on: November 09, 2018, 06:33:26 pm »
Or just a nozzle with a large rectangular face
Day Job: Mostly LEDs
