Make sure all of the boards are seated in properly if you haven't already. Things rattle around a bit whilst on the back of a truck.
Even worse than that! The original hard drive went bad, and they just laid another drive on top of it, not screwed down to anything.
So, that drive was flopping and bouncing around for 900+ miles from Austin to here. But, it boots up and loads the software.
Then, I had problems with the PC (Celeron 566 MHz) communicating with the VME computer (68020, I think). The ISA-bus interface
card is totally passive, but had 2 50-pin cables crimped to the board. I hate those things. One of them was coming apart, so I unsoldered the wire termination and soldered in a 50-pin standard header, and crimped a 50-pin female to the cable.
Then, it wouldn't go to the "ready" state, with servos powered. I eventually found a blown fuse.
Now, I can get it totally powered up, but there is a bad theta motor (nozzle rotation) on one head. This prevents it from homing the axes. The X, Y and each Z are brushless servos, but the rotation is done with 5-phase steppers. One of them seems to be bad, but with a weird symptom. Three of the wires show continuity with each other, the other two wires have continuity just to themselves.
That actually seems like a really weird failure for a 5-phase stepper. It just seems odd that it could have two isolated groups of coils.
(On the other motors, all 5 wires have continuity.)
I don't find obviously blown transistors on the stepper driver for that axis.
There's a huge amount of software functionality in their program, it will take me some time to learn my way around it.
Jon
