Well, I now have the schematics, they are horrible, and don't exactly match my machine. But, mostly they are close. I only got machine wiring schematics, NONE of the board schematics. Ugh, I was hoping for more detail.
I had an idea that the mysterious input point the computer shows as "power switch" might be used to interlock going to ready mode, but it is not hooked up to anything. I was able to ground that optoisolator input, and the input display does show "power switch" going on, but it had no effect on anything else.
So, I guess that is a feature unused in this model. DARN!
So, I'm still stuck with not being able to turn the servos on, which makes it pretty hard to do anything on the machine. It COULD be a defect in the IO_DPRAM board, where all of this action appears to connect, but it could be a software issue. Geez, you'd think there's be a diagnostic tree in the
maintenance manual, but no sign of such a thing.
Jon
