So, over the weekend I did a bunch of the front sides of those boards until I ran out of parts. I had a major fit trying to get the QuadAlign vision system to accept the SOIC-16 parts, although it accepted the SOIC-8 parts with the factory stock settings. I still don't understand what was going on there, but I just kept fiddling with parameters until it accepted the parts.
My old Philips CSM84 was certainly fast enough for me, this machine, running at 50% speed, is about twice as fast as the Philips, even when the Philips didn't have to go use the mechanical alignment station.
I still don't have the automatic nozzle changer working, it is clearly a software setup issue. Every time I start the system, I have to reset all the ANC settings and hole positions, and then it forgets them the next time.
The fiducial camera flaked out, but by swapping boards with a spare, I was able to get it running. Hopefully, I have gotten past the issue with boards going bad. I need to get a few more feeders and make some repairs on the ones I have, to have enough for the next boards I will be doing.
As for teaching boards, I won't have to do that. I have now developed a flow from the CAD system, through a C program I wrote, into the CAD import function of the QSA-30, but then NOT using their built-in "optimizer" which totally scrambles the placement data. It takes some additional hand editing of the placement data to assign parts to feeders, etc. but it works. I have to manually enter the board dimensions and fiducial location and settings, but then all the placement data is brought in from the CAD system. (correctly!)
I'm still getting used to the Quad feeders. At first, I was thinking they were going to take a LOT longer to thread and set up, but it now looks like it only takes a little longer than simple mechanical feeders. And, I had a LOT of trouble with my old Philips/Yamaha feeders not being able to peel the cover tape reliably. Once threaded, the Quad feeders seem to have enough pull to peel the tape reliably. This might actually be a BIG improvement that I was not expecting. On the old Philips, I had to constantly be leaning in there to mess with cover tapes and unjam them.
I still have to make a waffle tray holder or find an affordable one. And, I still need to calibrate the QuadAlign cameras. Placement is already better than my Philips most of the time, but I know that I have knocked these out of alignment when I disassembled things.
Just keeping the list updated on progress.
Jon
