If you run the same boards over and over, I have the Charmhigh 48VB.
The software is kind of really shitty, plan on checking over every component placement to make sure they are right. For some reason, it auto-rotates components in the builder, not sure why. It is usable, but just be prepared to go over it carefully to make everything right. Little things like vacuum detection and vision are tuned off by default, which is stupid.
The feeder system is good enough, but certainly not perfect. You do have to babysit the machine pretty much all the time. Usually what happens is the cover tape wasn't pulled back and so the nozzle can't pick up the component. The tighter you make the take-up reels, the more you run the risk of them being too tight and pulling out the component tape and wasting components and making a mess.
I run 150x200mm boards as a max, but only around 100 per month, and the same boards over and over, so it works for me. After I got it all dialed in (as far as the program), and learned the quirks, it is good enough for my needs at the moment. I do have my eye on a Neoden S1 as an upgrade though. That unit has more feeders, and feeders are traditional cartridge type (but proprietary I believe). That would allow easier swaps and far more reliable feeding, presumably. However, I'm looking at $25k USD for a full setup for the S1 where the 48VB cost me about $6000 landed. Oh the joys of a startup
