I have tried IR drawer ovens and they are crap, even with all the mods they are crap. I ended up sending my T962 to recycle bin. Even with IR shields I would get hot spots on PCB, burnt areas and then unsoldered areas. Was the T962 was total junk and waste of money.
I modified a 1/4 size oven with insulation, convection fan and heaters using the Controleo3 controller. It works well, the Controleo3 PID is a joke, but I was able to get it roughly follow profile with some hacking. I found the oven works well for leaded soldering but lead free I still have issues.
For lead free I found that the thermal mass of the PCB makes a big difference, specifically the Controleo3 only has one thermocouple. As such you have to manually configure the overshoot and soak times to compensate for the thermal mass of PCB. I wish there was a second thermocouple where you could attach thermocouple to unpopulated PCB and leave in oven such that you have one thermocouple for PCB and one for air temperature. Then the controller could dynamically change soak times, while not exceeding air temperature. Note I am considering doing another PCB design of the Controleo3 to add this or maybe even moving to Raspberry PI. I would really like to have a web interface, and hence a Raspberry Pi will most likely win. Anyone interested on helping with this?
Note something that is very important is to get an oven with exhaust. Either exhaust it outside, or run it through a carbon filter. The fumes from the reflow process, especially when you over bake a PCB are bad.
Also note that I double sided PCBs are a problem. I have to setup custom jigs to hold the PCBs to reflow second side. I am not sure how the conveyor units do this, I assume someone must sell a holder or something?
On the double sided lead free, I am finding that I can get first side to reflow great, as well as the second side. However when I reflow the second side, the first side gets burnt coloring like it is over heated. I have not root caused this yet, but suspect it is because of bad thermal control and air getting too hot.
If you want a good reflow oven, especially off 110V here are few things I learned:
1. For 110V operation with 15A circuit you really need to have low thermal mass. This means no metal inside heat chamber and good insulation. 1800W is barely enough to get 1 degree C per second ramp rate unless you have low internal thermal mass and good insulation. Better to just go with 220V and be done...
2. You want convection heating, you want all the air circulating to have same air temperature all over PCB.
3. IR is evil, it might work on conveyor systems (not tested). However in a stationary oven the IR does not work as it can cause uneven heating.
4. You need more than one thermocouple so you can measure air temperature and PCB temperature.
5. Do not buy the cheap gold insulation as mentioned on the Controleo3 website, that cheap stuff stinks even after years of use. I regret this purchase and really can not fix on my current oven.
6. You want external vented, again I can not stress this enough! Do not consider any oven that does not have means to exhaust fumes outside.
