Author Topic: small quantities of GC10?  (Read 559 times)
djacobow and 1 Guest are viewing this topic.
Online djacobow
  • takin' it apart since the 70's
« on: August 13, 2019, 10:51:25 am »
Currently using TS391SNL50 for lead-free home reflow. Lots of people seem to think GC10 is the bee's knees. Would like to try it, but am not thrilled about going in for 500g just to see if it is any better.
Is there a way to get smaller quantities in the US?
Offline pisoiu
Re: small quantities of GC10?
« Reply #1 on: August 13, 2019, 06:11:02 pm »
I made my tests with this one:
https://eleshop.eu/loctite-gc10-solder-paste-20g.html
They also have galden if you are interested in vapour phase reflow.
Online djacobow
« Reply #2 on: August 14, 2019, 12:28:14 am »
Thanks! If they ship to the USA, I'll give it a go.
Online djacobow
« Reply #3 on: August 14, 2019, 02:01:06 am »
Oh well, they want 80 euro to ship to California. For that, I might as well get 500g. :-(
Offline mrpackethead
« Reply #4 on: August 14, 2019, 09:57:21 am »
Are you intending on using it with a stainless stencil?  If you are lookign to use it for hand application ( ie, dispenseing with a needle ) then you will be dissapointed. The attributes that make it good for stenciling make it bad for needles.
Online djacobow
« Reply #5 on: August 14, 2019, 12:02:05 pm »
It is for use with a stainless steel stencil, but hand applied using a credit card, not a stencil printer.
There board is a little tricky. 15x15 cm, give or take, with many cutouts which can warp the stencil when pressure is applied if I'm not careful.
« Reply #6 on: August 14, 2019, 12:49:56 pm »
GC10 exhibits very low 'slump' and I'm not sure if its the right word, but i'd almost say its not very 'mallable' when it comes out of the jar.  ( this is why its not good for hand dispense ).    it is well worth 'working' the paste before you use it, so it 'softens' up a little bit.      If you have a stainless stencil, get a hard edge metal squeegee.  The results are so much better.    they can be purchased for just a few dollars from aliexpress.
Offline TimCambridge
« Reply #7 on: August 14, 2019, 07:01:38 pm »
Metal "wallpaper scrapers" seem to work well. Around $1. I expect the real thing is better, but $1....
Do the experts advocate framed stencils for "difficult" boards? A bit more expensive because of shipping, but still fairly cheap.
« Reply #8 on: August 14, 2019, 08:27:58 pm »
I got some on Ali for under $10.   They are really rigid and dont' flex, and have a very sharp square edge. thats really important.       Somethign like this.
https://www.aliexpress.com/item/32971053685.html?spm=a2g0o.productlist.0.0.731c2254atMjzy&algo_pvid=e3977f8d-3b22-49ab-a79f-00dd41c51544&algo_expid=e3977f8d-3b22-49ab-a79f-00dd41c51544-4&btsid=372c2674-ea48-44b2-9d91-abfdd2b500c7&ws_ab_test=searchweb0_0,searchweb201602_10,searchweb201603_53
I dont' bother with unframed stencils, becuase the results are just so much better, its quicker setup, with framed stencils.  The stencil held in tension.
The following users thanked this post: TimCambridge
Offline jmelson
« Reply #9 on: August 15, 2019, 05:02:06 am »
Well, the stuff has quite a long shelf life, and just works SO WELL, that I don't mind paying for a 500 g jar.  I've had excellent results with it, after having some pretty AWFUL results with what were supposed to be good brands - Indium Corp., Kester, etc.
Jon
Online djacobow
« Reply #10 on: August 15, 2019, 06:59:29 am »
I broke down and ordered some.
The biggest heartbreak for me right now is Vcc/GND shorts under decoupling caps. These are almost impossible to debug and I've thrown out too many boards. I have recovered board by removing each and every decoupling cap and yesterday I had luck b by putting a dab of flux over every cap and reflowing again.
I am pretty sure that if my printing technique were better, this would not be happening, but I also can't help but notice that I don't get this problem with leaded, even with my lousy paste printing.
We'll see if this works any better. In the meantime, I'll work on better paste application.
« Last Edit: August 15, 2019, 07:12:46 am by djacobow »
Offline jmelson
« Reply #11 on: August 16, 2019, 05:47:09 am »
Odd, I have NEVER had this specific problem!  I have had shorts under some chip scale packages, and those were maddening, indeed.  But, never under caps or resistors.  I do sometimes get balls of solder on the side of small passives, that is where paste got smushed sideways out from the center of the part.  but, it has never caused a short.
I have done over 2000 boards on my P&P and homebrew reflow setup.  I do manual paste application.  But, what I have found is to use a THIN stencil, and then reduce the paste apertures below pad size.  This is most important with small-pitch ICs, but helps with the passives, too.  I use a 0.003" (.075 mm) brass stencil that I make myself with PC board technology.  For the passives, I use an aperture about 50 - 75% of the area of the pad.  Oh, and I use either 0805 or 0603 passives, and not anything smaller.
Jon
« Reply #12 on: August 16, 2019, 07:58:04 am »
Your lead free paste probably was 'slumping' more.   That is something GC10 doe'snt do nearly as badly.. Slumping is when a 'blob' of solder bulges out sideways, when its still 'wet'.      However if your doing 0603's / 0805's then you're probabably got a technique issue, my first pick would be that the stencil is not gasketing well against the pcb, and that your possibly useing a flexible squeegee?
Offline thm_w
« Reply #13 on: August 16, 2019, 08:15:31 am »
I've also never seen this problem on 0603.
But its easy to diagnose a shorted cap with a thermal camera. Apply voltage across the shorted rail, then look on the camera which component is heating up. Could also use your finger or freeze spray, but thats a bit harder.
Offline SMTech
« Reply #14 on: August 16, 2019, 08:27:08 am »
Jon
If that is what is working for you then there is something freaky going on with either your  paste process, your pad size or both. That is a crazy reduction and  I would expect to see almost no solder fillet on the device if you went down to 50% with a stencil that thin, with a little bit extra added back on for your untensioned stencil.
Quite an effective way to reduce paste to compensate for manual printing is to use shaped apertures such as "homeplate", we're only talking 10% or so even then and this shape reduces the amount of paste under the device. That in turn should reduce the potential for shorts under passives and mid-chip solder balls.
If you drop the thickness of the stencil too much then you will find that devices with a centre ground/heat pad such as some QFPs will sit on the PCB above the solder and that pad will not be attached. I've had that happen with a 0.1mm stencil with a 0.5mm pitch QFP, didn't know it until I had to take one off, at which point of course I was quite glad, made removing it much easier...
Online djacobow
« Reply #15 on: Yesterday at 11:59:37 am »
A jar of GC10 arrived yesterday. The T3 variant seemed adequate, and the price was a bit less, but it was out of stock, so I got the T4 kind, which has slightly finer metal powder.
So far, I've done 10 boards with it, and none of them have had the shorting problem that I was seeing on previous boards. In fact, my pasting is not really much better, but even with the little slop I make, with gloops of paste sometimes spanning pads, the solder is balling up as it should and I'm not getting short. I have not tested the boards yet, but without the Vcc/Gnd fault, at least it should not be painful to clean up what issues that there might be. Overall, I'm quite pleased so far.
As for my stencil work, I am sure now that the problem is warping of the stencil when I pull it over parts of the board with cutouts. It causes the stencil to lift a bit in spots, causing the deposition of paste in that area to be too deep, and usually sloppy, too. I think my board might be a worst-case scenario for this. Here's a picture of a scrap board inside my stenciling "jig."
The issue is not caused by the cutouts on the inside of the board, but on the big voids on the three "corners" where the board is not in contact with the surrounding scrap holders. I think if I got up some board to tape in those spots, my problem might be mitigated.
« Reply #16 on: Yesterday at 04:47:43 pm »
wow. your up against it on that, with a unframed stencil.   absolutely with nothing under teh stencil, thats going to be a challenge.
yes, definately pack up some more pcbs in against those edges..
Online spongle
« Reply #17 on: Today at 12:30:33 am »
For complicated PCB outlines like that, I like to laser-cut a template to provide alignment and support the stencil. 1/16" acrylic is very close to normal 1.6mm PCB thickness..
If you don't have a makerspace close by, DirtyPCBs provides a reasonably priced service.
