Hi Michael,
The new machine looks impressive and will certainly fill a gap alongside the QiHe TVM920. I wish you the best of fortune along its development path and hope you can manage to contain the 'cost factor' of building in a Euro environment.
Good luck - Peter
Thank you Peter,
the cost factor is a problem but if you need industrial parts you can buy spare parts all over the world like Festo or Mitsubishi they sell on similar price in Germany.
The cabling is reduced by using CAN bus to connect the units.
For the mechanical alignment of a machine we use some tricks to increase the build speed.
Our new design has a reduced part count and clever combination of different construction techniques.
Over all we have 25% higher production costs than China but the machine has different construction quality and reliability.
We wanted a modular machine where customer can upgrade machine over time.
Not the same like all other products from China on the market now.
For example:
If we build a 4 nozzle pnp head you can upgrade your machine by changing the head unit. Only disconnect 2 cables and air pressure supply and release some screws.
After some time you may need another feeder bank. No problem mount the modular feeder unit, connect to power and bus add the air supply and you can use more feeders on your existing machine.
Our motion controller is running inside PC so we can offer a collission avoiding sytem in the future by building a 3d map of the PCB while placing.
This machine supports different Z placement height's if you want to build 3 dimensional structures.
Every peripheral unit is connected by CAN bus and include a CORTEX M4 controller powerfull enough to do all tasks easily.
We use linear scales to measure the current head position like all big pnp machines do.
This will help to detect any position error if the pnp head hits an object and loose position on normal positioning systems!
And finally our current PNP software is good but the new V3 softare will be a step ahead.
Best regards
Michael
