Ok back to the topic thank you for all comments.
I know there are many people who wan'ts to build their own machine and use Open source software.
This customer group don't wan't to spend to much money to buy a machine.
But over time they spend a lot of money because they need to buy improved parts or the result is not as they assumed.
So I decided to sell a base machine for office use to meet the needs for prototyping jobs.
The main difference to our bigger machines is it is easy to upgrade because we use and open design like a LEGO brick.
We have limited feeder count but the user can extend or change.
Our VP-2X00HP and VP-2X00D machines are fixed systems you receive a lot of feeder lines and big working areas.
Finally we receive 3 machine lines to sell: BASIC this new machine / MID VP2X00D Belt / HIGH VP-2X00HP spindle + servo motors + linear guidings
Read the user postings about other machines carefully!
- You need to run at 100% speed for small parts because vibrations are less (weak mechanical design!)
- Ambient light change affect my vision system
- I need to recalibrate my machine if I want reach the precision (calibration changing in short time!)
@mrpackethead
Your machines included machines? What do you mean. The new software use a hardware abstraction layer driver model to support different machine controllers.
We have 2 different machine controllers now the old V1 (2 head) and the current V2 up to 4 head controller plus 22 pneumatic feeder control.
The new V3 controller has CAN bus to control extensions
- more pnp heads
- up to 128 pneumatic push feeder
- CAN bus feeders
- retro fitting of old pnp machines possible
So it can be scaled from very small to big system.
