Anyone figure out the .ini file for Protel?
I'm getting an error "missing mandatory column ID in ini file".
Exporting the pnp file as a csv gives this:
1 6 3 4 0 0 0 0 2 7 5
"Designator","Footprint","Mid X","Mid Y","Ref X","Ref Y","Pad X","Pad Y","Layer","Rotation","Comment"
"LCD1","LCD_WINSTAR1602B","-65.996mil","1968.41mil","-1325.839mil","2588.488mil","-1325.839mil","2588.488mil","T","0.00","LCD 16X2 WINSTAR 1602B"
My .ini file says this:
3
1,6,3,4,0,0,0,0,2,7,5
SmtAssistant configuration file
Syntax :
Line 1 : Number of lines to skip when reading a PKP file
Line 2 : Field separator between columns of the PKP file
Line 3 : Respective indexes of the PKP columns, as follows :
Mandatory fields :
1 : Part ID (string, should be formed as letters followed by a number, as R101 or CP5)
2 : layer (any string starting with B or b will be understood as Bottom, else Top)
3 : X (should be a signed decimal number, separator is a dot)
4 : Y (should be a signed decimal number, separator is a dot)
Optionnal fields :
5 : Value (string)
6 : Package (string)
7 : Rotation (should be a signed decimal number, separator is a dot)
0 : unused
Strings could be either enclosed between double quotes ("STRING") or
without double quote if they never include the separator character
