Author Topic: Companies that can work with ceramic substrates  (Read 1928 times)
Offline RayuelaTopic starter
  • Country: cl
« on: June 19, 2023, 12:02:53 pm »
Hi Everyone,
The attached picture shows a Blackrock connector commonly used in different Brain computer interfaces. I need to search for a company that can make a PCB or ceramic substrate job that will allow vias or pads to be metalized from one layer to the other with a pad size of 200-300µm and with a pitch between pads of 500µm.
Offline PCBprototyping
  • Country: si
Re: Companies that can work with ceramic substrates
« Reply #1 on: June 19, 2023, 12:51:20 pm »
LaserMicronics is LPKF's company for services on LPKF's equipment, try them.
LPKF manufactures UV laser systems, like ProtoLaser U4, that are capable of cutting ceramic boards.
They also have via plating system, 0.2 mm via is the minimum size.
  • Country: cl
« Reply #2 on: June 20, 2023, 07:03:21 am »
Thank you mate! I'll give them a try
Offline stone
  • Country: hk
« Reply #3 on: August 09, 2023, 04:04:32 pm »
Ceramic substrate
