Hello!
I bought this 990FX AM3+ motherboard. When I first took it home, I met the seller and it was freezing cold.
Went home, put a cpu and it just POSTED fine for a while.
After some time I wanted to build a fast machine to test more cpus but this time no POST.
Pushing down the cpu would get me some POST codes but that was it. Maybe different stages and different codes but the same stuff basically.
Been pushing too much and it won't issue codes anymore, I guess more solder balls broke.
My diagnosis is: an issue with the socket and it needs a reflow (better would be a replacement but I'd fail as I don't have the correct equipment).
I ASK:
how should I proceed to reflow it? I have the usual basic solder station (iron + air).
I thought tons of flux on top and going from 100°C ---> 150° ----> ... ----> 350°C. Up to 200°C being a preheat and adding flux afterwards.
Sounds right? Mistakes? Advice? I'm all ears!!
Thanks in advance!!
