This is freshly etched copper.
yes and it was not clean enough even before etching.. copper must be shiny, if it's not, the you end up with issues. i make my own boards as well , soldering with a looong expired paste and never have issues.
expired solder paste is not a problem for hobby use with hot plate or hot air ( but it would be a big issue for production). you just need to add a bit more than usual and visually check when it flows.. you can't rely on the original temperature profile with expired paste.
if your paste is dried out, then add a little bit of flux + a bit of IPA, stir it up, work it with a spatula for a while till it has the "good" consistency and it's good as new for hobby use
