Author Topic: Making PCBs using Conductive Ink Printer (ie Voltera V-One)  (Read 3388 times)
Offline DerekGTopic starter
  • Country: nf
« on: September 06, 2017, 03:27:52 am »
A colleague sent me the link below to the Voltera V-One Conductive Ink Printer that is designed to lay tracks down onto either ridged or flexible circuit board substrate (or plastic or almost anything flat).
https://www.circuitspecialists.com/voltera.html
I understand that conductive ink can also be used to fill through hole vias.
The Voltera conductive ink printer can read Gerber files in directly.
These are of interest as it could mean a prototype circuit could be "produced & tested" in an afternoon.
I'm wondering if anyone has used either the Voltera printer (or another brand) & how successful they have found them in real life.
I also sat between Elvis & Bigfoot on the UFO.
Offline cdev
Re: Making PCBs using Conductive Ink Printer (ie Voltera V-One)
« Reply #1 on: September 06, 2017, 03:32:18 am »
With the caveat that I have always wanted to do conductive ink for other reasons, I can make my own prototype PCB in an hour or so now. Ghetto style. So that may not be such a big thing because lots of people can and do make their own PCBs in a short periodof time using toner transfer or similar.  Its less complicated than people think.
Offline mairo
« Reply #2 on: September 06, 2017, 10:05:31 am »
not in the Voltera price range, but this might do a better job:
http://www.nano-di.com/3d-printer
Offline phil from seattle
« Reply #3 on: October 29, 2017, 07:56:11 pm »
The video had zero details on how you attach components. Solder? Fused deposition materials typically have a low melting point - solder would be problematic.
Online Kean
    • Kean Electronics
« Reply #4 on: October 29, 2017, 09:50:33 pm »
From what I recall reading, it supposedly works OK, but has limited use cases and expensive single-source consumables.
In these days of cheap online PCB ordering (even recently for flex), it would be awfully hard to justify - but sometimes you need a one-off sample same-day (education, high-value prototyping).
I'm guessing Circuit Specialists are just a reseller - the company website is https://www.voltera.io/
The original Kickstarter is at https://www.kickstarter.com/projects/voltera/voltera-your-circuit-board-prototyping-machine
There is some older discussion on the Voltera in the Crowd Funding section of this forum
https://www.eevblog.com/forum/crowd-funded-projects/new-kickstarter-voltera-print-paste-and-toast-)-your-prototype-board/
Online tooki
« Reply #5 on: December 31, 2017, 01:27:59 am »
At least a while back when I first saw the Voltera, they specified a low-temperature tin-bismuth (IIRC) solder.
Offline ar__systems
« Reply #6 on: January 08, 2018, 03:41:22 am »
So what do you do with the single side PCB with no mask, no legend, and no holes?
« Reply #7 on: January 08, 2018, 10:41:52 pm »
Well, in theory it could print multiple materials: insulators (for trace crossings), ink for legend, masking ink for the solder mask.  Resistors and caps could be printed. Maybe even thick film devices. Probably would require significant mind shift in how boards are designed and laid out. Plus, a lot of new tools and materials.
Theory might be a bit ahead of reality, though... :)
