Author Topic: Solenoid design  (Read 206 times)
Offline pisoiu
Solenoid design
« on: January 08, 2020, 02:52:03 pm »
I need a solenoid with very specific dimensions and there is none available so I must build one. But I'm stuck with the shell material.
Can anyone recommend me a supplier (in Europe preferably)  of soft iron or other metallic compounds which can be used to build magnetic circuit of solenoid? The shape is cylindrical, 22mm in diameter.
Thank you.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Solenoid design
« Reply #1 on: January 14, 2020, 11:02:06 pm »
I know there are a bunch of manufacturers in Japan that make custom solenoids, for example TAKAHA
https://www.takaha-japan.com/
As a side note they made a cool manga too:
http://www.takaha-japan.com/wp-content/uploads/2017/01/Solenoid-Cartoon.pdf
