Author Topic: SRA Ultrasonic Cleaners - any good?  (Read 3089 times)
Online deanclaxtonTopic starter
« on: July 13, 2021, 06:22:58 am »
I'm looking at purchasing an SRA UC-32D-PRO-220 ultrasonic cleaner (220V). Does anyone have experience with this brand? Its available at Digikey with delivery to Australia but I'm curious how well it compares with other brands out there for reliability, such as Crest which seem very well regarded.
SRA Products here
« Last Edit: July 13, 2021, 09:36:20 pm by deanclaxton »
Offline phil from seattle
Re: SRA Ultrasonic Cleaners - any good?
« Reply #1 on: July 13, 2021, 05:58:35 pm »
following...  That looks like a good size (I need to do 100x100mm boards frequently) and the price is right.  Unfortunately, every one with a reasonable price that I've looked at gets terrible reviews and I can't justify dropping 600 bones for one that gets good reviews.
« Reply #2 on: July 13, 2021, 09:32:29 pm »
Yeah they of course have a full range of 110V machines also. Like you said they seem well priced and come with the baskets/racks etc. The SRA UC-45D-PRO has a bit more power, and an extra transducer for $50 more (as well as a 1.1-4.5L capacity vs 0.8-3.2L capacity). Not a lot more solution to fill to the minimum mark (1.1L vs 0.8L) - maybe thats the way to go.
« Last Edit: July 13, 2021, 10:19:27 pm by deanclaxton »
« Reply #3 on: October 25, 2021, 09:54:38 pm »
Well I ended up buying a cheapie off eBay (AU$249) - 10L though so will fit my (frameless) stencils in there as well : https://vevor.com.au/collections/ultrasonic-cleaner/products/ultrasonic-cleaner-10l-150-300w-degas-jewelry-cleaner-ultrasonic-cleaner
Hopefully it will last a couple of years at least - we'll see.
Offline Rat_Patrol
« Reply #4 on: October 25, 2021, 11:52:51 pm »
I run a few. Had an issue with one, their CS was great to me.
No other issues.
The following users thanked this post: deanclaxton
Offline alexaraujo
  • Country: br
« Reply #5 on: October 27, 2021, 02:08:57 pm »
I have a small 1L ultrasonic cleaner that cleans some types of plates.
But I have questions about a problem with cleaning my board.
I clean with isopropyl alcohol, but in the Lqfp type components there is a white sludge in this region, how can I not put this white sludge on these pins?
After washing, I use a dryer for the final drying of the board.
Offline Kean
    • Kean Electronics
« Reply #6 on: October 27, 2021, 04:41:16 pm »
IPA can leave a white residue with certain fluxes.  Use a different cleaner.
Lots of info can be found about this - maybe start with these topics:
https://www.eevblog.com/forum/manufacture/residuediscoloration-after-ultrasonic-cleaning/
https://www.eevblog.com/forum/manufacture/ultrasonic-pcb-cleaning-white-residue/
« Reply #7 on: October 27, 2021, 09:30:42 pm »
Some cleaners are very expensive, but the Chemtronics Flux Off Aqueous  (https://www.chemtronics.com/flux-off-aqueous) is reasonably priced. I've only used it a little bit at work, but seems to work nicely. Removes any flux residue from the solder pastes I use (GC-10), IF8300 BGA gel flux and also the brushable residues from the IF14-14 leaded solder I use for through hole work.
Offline Radioman23
« Reply #8 on: December 18, 2021, 08:32:54 am »
No other issues.
Pardon my asking, but have you had a chance to compare the SRA machine with, say a Crest?   I am very curious to see how well the SRA cleaners would do in removing corrosion or BGA contaminants.
Offline Rat_Patrol
« Reply #9 on: December 20, 2021, 05:08:29 pm »
No other issues.
I have not.
