Well, I'm sure that each IC will have ground on a different pin, so you would have to make a custom order in order to actually connect the IC to the bottom ground plane. Wouldn't having a large copper plane connected to nothing (as would be the case with a standard one size fits all adapter) just make it worse for RF applications, as it would act as an antenna instead?
