You'll find a bunch in very similar larger footprints like the 9x6mm Bourns one linked above, but at 3.2x2.5mm (1210) and that rating there doesn't seem to be much available apart from the TDK ACP3225.
You don't mention the filtering specs you need, but Wurth have one that might suit in 4.5x3.2mm (1812).
https://www.we-online.com/catalog/en/WE-CNSWMurata had some similar small ones but I recall they went NRND. Yeah, the DLW44 series - 4.0x4.0mm. Looks like some new ones are coming to replace them.
So, I think the answer is no. If you have the space then try go for a larger part or place multiple alternative footprints. Or buy up big in advance.
