While browsing taoboa for random things I found this:
https://item.taobao.com/item.htm?spm=2013.1.20141003.10.rKoPcY&scm=1007.10011.60084.100200300000001&id=25948908047
https://gd2.alicdn.com/imgextra/i2/1037288188/TB2.hiInXXXXXbVXXXXXXXXXXXX_!!1037288188.jpgSupports yamaha CL feeders, only has (shitty?) bottom cam but has HIWIN guides and "real" samsung or whatever pick and place heads. It looks like a solid base to port to OpenPNP or liteplacer software.
It's about 1600 euro which is close to a liteplacer kit. They also offer a "DIY" version of this but I'm not exactly sure what that entails (see bottom of post). Is it assemble yourself or is it even more limited as in not complete components.
I have a liteplacer; software is "good enough" hardware is ok except the pnp head could be better. And it really misses feeders.
This "platform" seems to fill that gap. Just make it use decent software and stick a camera on the head and you should be done.
I bought a Yamaha CL 8mm feeder to see what it is all about and I must say that it is an excellent piece equipment that is really well made and works without issue (even manually). And for 26 euro you can't complain.
Specs:
Main technical performance
Chip effective size: 280mm * 400mm
the XY axis movement range: 400 × 400mm
the Z-axis moving range: 15mm
Number of heads: 2
Feeder Quantity: supports up to 24 feeder
placement speed: 4000 / hour
placement accuracy: ± 0.03mm
Original size: 0402-5050, SOP, QFN
device dimensions: L880mm × W 620mm × H 310mm
Vacuum: vacuum-type vacuum generator
Power: 220V, 50Hz
Power: 250W
Weight: 45kg
http://v.youku.com/v_show/id_XMTc2MDQyNzU4MA==.htmlhttp://v.youku.com/v_show/id_XMTM1NzE3MTYyNA==.html?spm=a2hzp.8244740.0.0&from=y1.7-1.2This seems to be the software?
http://v.youku.com/v_show/id_XMTM1NzE3MTYyNA==.html?spm=a2hzp.8244740.0.0&from=y1.7-1.2Diy kit:
The price of 6800 excluding electrical control, solenoid valves, visual camera and other accessories. Full set of accessories 9800 yuan (excluding visual).
I might get one around FEB and look how well it performs stock and if needed port it to openpnp or liteplacer or any other suitable pnp software. It uses steppers so that should not be that hard.
Just thought I trow it out here; others might find it interesting;
Edit:
To improve accuracy one could add closed loop steppers to it. I have this on my cnc and they are excellent.
Can support 4000 ppr encoder. A set is like 100 euro for a driver and a motor (2Nm)
Also seems fairly easy to add ballscrews to this and another two PNP heads if one is interested in that.
