For a jig testing a very thin PCB, I plan to use spring-loaded pins that can be automatically assembled, such as
https://jlcpcb.com/partdetail/Xinyangze-YZP0652_1507201/C5157254- As far as I know, P100 pogo pin are typically used for such a task.
Any reason why SMT pins should not work? - the test points have ENIG surface
- the lower force of about 50g should be ok
- the precision of the pin is anyway higher compared to P100
- to keep deformation of the jig-PCB minimal, there is direct mechanical support on the backside of the pins
- there are no receptables, so the pins cannot be easily replaced. That's ok because the jig-PCB is cheap enough.
- Are there any positioning pins which center the PCB-under-test that can be automatically assembled?
