Author Topic: Hi Flex cables for USB2.0 and USB3.0 options  (Read 2031 times)
Offline glenenglishTopic starter
  • RF engineer. AI6UM / VK1XX . Aviation pilot. MTBr.
« on: April 25, 2018, 12:55:18 am »
Having broken a cable now in the elbow of  in my USB camera equipped TVM920 pnp, I have learned a bit about hi-flex cables.
These are cables rated at millions of bend cycles on small radii
There are a few sellers of cables, and EXCELLENT cables like jargy.com.tw ... and about USD135  for the USB3.0 3m cable.  about USD35 for USB2.0 cable.
There are a few high flex data cables like belden 7201 series etc for 485, CAN etc, 40 x 40 AWG strands... but these are quite lossy at 100 MHz... no good.
Has anyone found a good high flex - (high strand, good jacket) option  ?
I thought of using some high flex  Cat-7 ethernet cable (which will carry USB3 even with impedance mismatch)  . if I can find some without having to buy 305 meters of it :-) .. Most Cat7 cables have cheap jackets unsuited and 7x0.16  strands, also unsuited .
options , ideas, discussion
cheers
glen
Online wraper
  • Country: lv
Re: Hi Flex cables for USB2.0 and USB3.0 options
« Reply #1 on: April 25, 2018, 01:35:07 am »
Original cables for mobile phones usually are quiet good in this regard (except apple). I guess decent aftermarket ones could be too. I use them as a source for repairing some devices where cable gets bent a lot. It is hard find a comparable bare cable without connectors. BTW why would you need USB3.0 ? :-//. It has 4 additional wires which you won't use anyway.
« Last Edit: April 25, 2018, 01:42:13 am by wraper »
« Reply #2 on: April 25, 2018, 02:36:22 am »
those cables are all crap.
need to be < 36 AWG in diameter per strand.
USB 3.0 if you want low latency and high frame rates (with at least megapixel res)
Online wraper
  • Country: lv
« Reply #3 on: April 26, 2018, 10:34:19 am »
Why do you think they have thicker strands? Most such cables have a big number of strands much thinner than that. On the other hand, USB A to B cables have very few thick strands as they are not intended to be plugged daily.
