Author Topic: SMD resistor cost has increased many times... or "artificial" shortage?!  (Read 1739 times)
Offline olkipukkiTopic starter
Sometime ago I made a "stupido" decision to buy all available 0603/0805 1% smd resistors from same series, just in case and having immediately access to these...  :phew:
Yes, that's right, more than 1000+ values  :palm: and make things worse, some of the were not available in small qty (such as 500 or 1000 pcs), but only in reels.
Since then, never looked how much and so, mostly apply only smaller 040n/0201 limited values for new projects, until noticed that some 0805/0603 values are running out and consider to top-up these... Wow, at the time a cost was between 0.001 and 0.004 max, now at least 0.006 to 0.01nn  :o
That's interesting (quick google search):  http://www.advancedmp.com/resistor-shortage-why-and-how/
You've started three threads on component shortages/supply chain issues in under an hour. Perhaps just one thread on component shortages would be a better idea.
« Last Edit: April 28, 2018, 02:22:38 pm by Cerebus »
