This is fascinating reading. Someone a couple of years ago asked my advice about buying their own pick and place. I said “no way, don’t do it”. They did it. I’m not sure they have ever made a single successful run of boards from the thing. This thread vindicates my advice somewhat. Thanks to those who have honestly documented their experiences here.
With all the pain and suffering....I still don't think I could have what I have today without the P&P. The more I use it, the better I get. The better I get, the more my little business grows. I REALLY REALLY REALLY wish it was easier....but no pain no gain I guess. My direct competitors all have slower time to market and higher costs overall. The difficult learning curve has earned me a competitive advantage in the end.
Something to note is that having your own P&P for only your own jobs is a very different situation from being a subcontract manufacturer doing work for multiple clients, all with their own systems, requirements, quirks etc.
Something that you absiolutely must not even consider is paying for the machine by running jobs for other people. That;s a whole different ballgame.
Seriously correct. A few people have asked if I can help them assemble. The answer is so easy.....NO. No way. Impossible. Unless they buy out my entire business.
It is, like Mike stated, a totally different universe trying to make boards for other people. I have my little internal system that closely matches my designs - and even that is a very big challenge.
I would rather have my machine sit powered down for months than try to 'keep it busy'.
IMO, I think it would be very helpfull for anyone wanting to setup his own SMT line to spent one day in an actual SMT assembly house from scratch to final product.
There is some wisdom there, but only if you are setting up a commercial operation. A small in-house system that only does in-house designs is at least a more simplified task. Manual printing is fine, no need for AOI or flying probes, etc. I am not sure I know of any good ways to gain an understanding of the PCB assembly reality without actually doing it. That is the majority reason for this thread. Hopefully not a depository of complaints, but something that will paint a realistic picture of what it is like. There are a lot of discussions that focus on machines and specification when the most important thing to focus on is the WHOLE process.
My personal progression into to P&P:
Started with Weller WES51 soldering station, manual solder paste syringe. Manually placed with tweezers, soldered each joint with the iron.
EFFECTIVENESS: Totally F'ing stupid
Found a small batch oven and started ordering prototype stencils. Still placing with tweezers from a box full of parts.
EFFECTIVENESS: Got through some simple prototypes
Added a vacuum pen and fabricated some cut tape holders to organize parts. The vacuum pen is still in use today and I love it. Tweezers are rotten. Also got an Amscope stereo microscope.
EFFECTIVENESS: This really sped up the process and reduced the mental anguish. Now I could do pilot runs of small designs. 10-20 pcs before I went crazy. The microscope immediately revealed tiny bridges and other flaws that were causing problems.
Added a stencil printer, color-coded part trays, and color-coded assembly guides that I printed and had as PDF on a computer monitor.
EFFECTIVENESS: This allowed more complicated designs to be hand assembled. The stencil printer is a piece of junk, but far better than the loose prototype stencil taped to my bench. The parts organization was a huge boost for speed and accuracy. This is where I achieved my max speed assembling manually. At the time, I had (3) double-sided boards that needed to be assembled. I did them in batches of 5-8 at a time
NOTES: Other important gear I picked up along the way that was important - pneumatic syringe dispenser for solder paste and SMD adhesives, hot air machine, upgraded the Weller WES51 to a JBC (life changer), a solid variety of vacuum pen heads.
This is when I purchased the P&P machine but continued to manually assemble PCB for many months (right next to the machine). As the machine slowly came to life.....it was clear I had to take all my previous tools and knowledge and create a system of sorts. I was now in a position where I was more process/skills limited than hardware/tools limited. I did not log the time it took to fix and modify the machine. I also have no real idea how much learning curve I have put into all of this. I do know that I would fail miserably trying to manually assemble my current designs even with my low volumes. I have too many small and fine pitch parts.
Becuase of the path I chose, I have very little experience sending boards out for assembly. The limited experience I do have showed me that it is not easy or fast or cheap.
