I think I'll build a custom made thing, even though it will probably take around a year to make I'm still confident that the end result will be much better than buying Chinese.
Well, I have only used name-brand "professional" machines, bought used. I have had 2 machines, a Philips CSM84, made by Yamaha, similar to their CM84, and a Quad QSA30A, made by Samsung on their basic CP30, but with Quad electronic feeders and component vision cameras.
If you have never run a P&P machine, you will not appreciate the amount of attention to error recovery required! My QSA30A inspects each part for X, Y and height dimensions, and discards parts that don't measure right, as that probably means the part was picked up sideways on the nozzle. Even my old Philips machine would try to pick parts 4 times before stopping and asking for manual recovery. The QSA will try 3 times, and then give up on that part, but will remember that that particular part type has not been placed. Once it finishes the board, you can reach in and clear the feeder jam or whatever the issue was, and hit start, and it will place those skipped parts. Pretty neat! Also, there is a LOT of setup testing help built into the system. When setting up the fiducials, there is a "scan test" button, and it will go the the location of each fiducial and then image it and tell you the offset from the nominal location, and wait a second for you to view how it located the centroid. There is also a test pick button, that allows you to pick up a part and it will run the vison tests and tell you what the part size was and how far off from the center of the nozzle. Also, you can use the down-looking camera to check and adjust the pickup position of every part, to improve pick-up reliability. All of these software features probably took a while to develop.
Jon
