Hi Everyone!
I'm wondering if anybody has any suggestions on the best way to cut out a PCBA, or more specifically a rigid-flex PCBA, out of its retaining frame. My PCBA has a very irregular shape with many radiused inside and outside corners, arcs, and small small rigid off-shoots connected to flex. Imagine something like this, but with many more flex sections coming off into many more rigid sections:
There are mouse-bites on all over my PCBA outer edges, holding it to the frame, similar to the above photograph. It is not possible to twist out all pieces of this PCBA by hand because it would rip and/or put stressed on the flex parts, some of which are only 2mm wide. For the time being I've been using some Hakko flush-cut pliers intended for copper wire, and that sort of does the job, but leaves a very rough edge and creates micro tears in the FR4. It also wears the metal of the cutters fairly quickly.
The other consideration is that the space between the PCBA and carrier frame is 1/4" or so. Any kind of hand cutters or nippers would need to fit in between this 1/4" gap, and be able to cut a straight line in the FR4.
Are there any standard tools for cutting out PCBAs from their carrier frames, other than the flush cutters I already described? That can (a) withstand 1000's of cuts through FR4 (b) leave a rather clean edge (c) not cost $10000?
