Please remind me what is the advantage of applying the film on the PCB at home rather than buying a ready made photo resist coated PCB?
1. Cost, film is cheaper
2. Flexibility, apply film to any size board, which you can cut, drill, sand, clean, etc to your heart's content before applying film
3. Screw up an exposure with a precoated pcb then you have something not useful (unless you use it with a different method), with film, strip off the film and start again.
4. No dark space required, work under normal household lighting conditions
5. Film is negative acting which may be advantageous if your print is a bit light
6. Develop and strip safely with Sodium Carbonate (Washing Soda, from any supermarket), no need for somewhat more dangerous Sodium Hydroxide (lye, the stuff used in soap manufacture and for example in Fight Club).
