Pretty interesting solution. I would definitely check if this whole assembly has been certified by someone.
Chances are the manufacturer was thinking "just toss the certified pack in there and slap a CE sticker on top, and we should be good". Obviously it doesn't matter if you use certified components or not if the whole assembly isn't certified.
