Electronics => Manufacturing & Assembly => Topic started by: bytestorm on July 13, 2018, 07:05:46 pm
Hey all!
I am trying to find somewhere to buy this type of pin. The regular pinheaders are not flat, but square, so when used in a IC socket they damages the socket.
However I do find alot of small pcbs with this kind of flat/slim pins that make the adapter pcb fit just like a chip in the socket..
Anyone knows what they are called and where I could buy a larger quantity?
(the measures in the pic could differ a bit ofc)
Thanks!
I typed "single row Header" in Ali and got:
https://www.aliexpress.com/wholesale?SearchText=single+row+header (https://www.aliexpress.com/wholesale?SearchText=single+row+header)
You get a lot of results with the thick square pins, but also quite a lod with round pins, which are quite a bit thinner.
I measured 0.63mm on the square pins I have and 0.48mm on the round pins and these fit nicely in the "high quality" IC sockets with round holes, but are still to thick for the stamped IC sockets.
I use "machined" or "turned pin" pin headers extensively for this sort of thing.
Thanks to both of you for the tips. Sadly, the majority of the places I want to use them for have regular stamped sockets :(.. hmm
0.018" round pins will work with ordinary DIP sockets without damage. They also fit perfectly in machined pin sockets. I use round pin header strips that are 0.018" on one side and 0.025" on the other for making PCBs that plug into DIP sockets.
Where can I buy that type and what's it called? So I can be sure I get the correct ones :)
it looks like it could be one made by zierick??
http://www.zierick.com/pages/sm_edge_sd1699.php (http://www.zierick.com/pages/sm_edge_sd1699.php)
Hope that helps. Good luck.
TheRadioGeek
I think that Mill-Max makes them if you want top quality. All that I have used are from eBay. Search for "round header -socket -female" and look at the pictures. It is easy to spot the type that you want.
A few examples...
https://www.ebay.com/itm/301747757572 (https://www.ebay.com/itm/301747757572)
https://www.ebay.com/itm/171830872054 (https://www.ebay.com/itm/171830872054)
---Edit---
Mill-Max 350 series
https://www.mill-max.com/products/socket/350-XX-XXX-00-001000 (https://www.mill-max.com/products/socket/350-XX-XXX-00-001000)
0.018 round pins also work great in breadboards
If you really want the stamped metal pins... https://batten-allen.com/uploads/pdf/DIL-Catalogue2012.pdf
They are more difficult to work with than headers.
Some pics of a project I did that uses the 0.018/0.025 round headers. Eight old 2716 EPROMs that I have no practical way to program are replaced by a single 27C128/256/512 EPROM. The small PCB plugs in to an ordinary stamped contact socket for the 74LS138, and the larger PCB plugs in to one of the machined pin sockets for the 2716. The pins work great for both types of DIP socket.
Flip-Pins (http://oshchip.org/products/Flip-Pins_Product.html) sound like what you want.
Exactly this, the "machined" or "turned pin" pin headers work perfectly well for stamped sockets without deforming them. Usually one side is thicker than the other, aim to use the skinnier side to mate with your socket and solder the thicker side on your breakout. Either way, these header pins are a lot skinnier than your average square cross section header pins.
Perfect!! Now Ill just have to decipher the datasheet to get the correct ones but now I have all I need! Thanks ALL!! :D
By the way, have a look at these new ones!! https://www.mouser.se/ProductDetail/575-3169061150000030 (https://www.mouser.se/ProductDetail/575-3169061150000030)
Dont see how many is included thou? Or are they really 0,5€ EACH??
They are usually in single in line break off strips of 20, 32 or 40, like normal headers, but with turned/machined pins instead of square cross section.
I usually buy them in bulk when I’m in SE Asia, but I’ve bought them from Farnell at a price when desperate, Harwin D01 series for example.
Plenty of options on Amazon and eBay, eg:
https://www.amazon.co.uk/2-54MM-40WAY-TURNED-HEADERS-PACK/dp/B01HZU84Z0/ref=sr_1_2?ie=UTF8&qid=1531605204&sr=8-2&keywords=Turned+pin+header (https://www.amazon.co.uk/2-54MM-40WAY-TURNED-HEADERS-PACK/dp/B01HZU84Z0/ref=sr_1_2?ie=UTF8&qid=1531605204&sr=8-2&keywords=Turned+pin+header)
https://www.ebay.co.uk/itm/5-x-32-Way-2-54mm-Turned-Pin-Single-In-Line-SIL-Header/263739555004?epid=22020174471&hash=item3d681a3cbc:g:8m4AAOSwpHpbFv4K (https://www.ebay.co.uk/itm/5-x-32-Way-2-54mm-Turned-Pin-Single-In-Line-SIL-Header/263739555004?epid=22020174471&hash=item3d681a3cbc:g:8m4AAOSwpHpbFv4K)
The highest pin count headers are usually the least expensive per pin.
https://www.digikey.com/products/en?Keywords=350-10-164-00-001000 (https://www.digikey.com/products/en?Keywords=350-10-164-00-001000)
https://www.mouser.com/ProductDetail/Mill-Max/350-10-164-00-001000?qs=%2fha2pyFaduhDvZDPn%2f2z5T%252bo%252bnEPXC7aiBA9A2yMPyq5gsVHvUGDIyEXP4cyMMWG (https://www.mouser.com/ProductDetail/Mill-Max/350-10-164-00-001000?qs=%2fha2pyFaduhDvZDPn%2f2z5T%252bo%252bnEPXC7aiBA9A2yMPyq5gsVHvUGDIyEXP4cyMMWG)
http://www.newark.com/mill-max/350-10-164-00-001000/board-to-board-connector-header/dp/17C5068 (http://www.newark.com/mill-max/350-10-164-00-001000/board-to-board-connector-header/dp/17C5068)
this pins named leadframe, search on google you will find many suppliers, heres one:
http://www.yrdzkj.com/ (http://www.yrdzkj.com/)
but this website is in Chinese.
http://www.ctmgdq.com/enindex.htm (http://www.ctmgdq.com/enindex.htm)
this is english website, but their output is 50 million per month, I don't know if they will accept your order.
