Author Topic: Which Aixun soldering station  (Read 1144 times)
Offline Raziel92Topic starter
« on: December 07, 2022, 07:21:06 pm »
Which model of Aixun soldering station have the lightest stick and the most flexible cable?
Till now im using Xytronic LF-8800 desoldering station and Bakon 950D which i really like a lot
What I need
Flexible cable
Small tickness tips 0.15mm
Short distance from tip to the handle
« Last Edit: December 07, 2022, 07:29:24 pm by Raziel92 »
Offline thm_w
  • Non-expert
Re: Which Aixun soldering station
« Reply #1 on: December 08, 2022, 12:11:58 am »
« Reply #2 on: December 08, 2022, 07:20:10 am »
There are lots of them, the station will be used in audio service, 5-6h per day, 4days per week
Which one is the most reliable? I also found I2C station which seems to be close clone to JBC
My budget is about 400 euro
Also id like to get station with linear power supply which should last much longer
« Last Edit: December 08, 2022, 07:23:03 am by Raziel92 »
Offline loki42
« Reply #3 on: December 08, 2022, 10:26:13 am »
For that kind of money you can get a used Metcal MX500 on ebay.  Great handle distance great tip range and they are indestructible.  The power delivery great too.  I've used mine for soldering down to 0201.
« Reply #4 on: December 08, 2022, 04:23:41 pm »
I would like to buy new station
Help me to decide, get t3b with SMPS or single/dual t420 with linear power supply?
Or maybe I2C will be better choice over t420?
Offline robdejonge
  • Country: th
« Reply #5 on: April 03, 2023, 06:20:09 am »
What did you end up getting? And how has it been?
Offline heygeorge
  • Country: sg
« Reply #6 on: April 06, 2023, 09:51:51 am »
Did you end up buying an AiXun soldering station? Share your experience
Offline thm_w
  • Non-expert
« Reply #7 on: April 06, 2023, 08:28:38 pm »
See the links in the second post.
