Loading [MathJax]/extensions/Safe.js
Author Topic: Mini wave / selective wave soldering  (Read 2952 times)
Offline loki42Topic starter
« on: February 15, 2024, 01:30:25 pm »
I'm attempting to use mini wave nozzles with my Ebso selective machine instead of the standard jet or wetable nozzles. I'm not sure if there are any guidelines for the mini wave as the documentation doesn't mention them at all.  Should I only move in one direction with the mini wave?  Should i dip in z(up / down) or should I move forward and back at the same height?  How far past a pin should I move and what is the best speed and wave height?
Offline IconicPCB
Re: Mini wave / selective wave soldering
« Reply #1 on: February 16, 2024, 06:11:07 am »
Loki G'day,
I have a small selective soldering fountain with selectable nozzles , wave height, pot temperature and solder pump duration controls.
Depending on the alloy give Yourself 40 to 60C head room in solder pot temperature over liquidus.
Depending on mechanical aspects of components You are soldering, give Yourself sufficient jet height for solder to penetrate the PTH hole but not flood the top surface.
Depending on componentry ( heavy leads?) and recommended soldering process window set the contact time with the solder jet accordingly.
Generally I select the nozzle to suit the range of components ( for example I use a 30mm nozzle to solder a row of pins on a relay ).
At 240C I typically set contact time for 3 to 4 seconds for conventional undemanding components.
The other important aspect is the flux. I have settled on an a flux from AIM not because it is the best but because it is the best readily available i have found.
I would be interested to hear which flux You are using.
As You can imagine since I am talking manual operation, I solder an area / set of features at a time and then when the solder pump subsides I move onto the next feature.
The following users thanked this post: panic
